NP DiD Pajero Exceed I need a snorkel.
Submitted: Wednesday, Nov 18, 2009 at 15:53
ThreadID: 73832 Views:9303 Replies:10 FollowUps:18
Which is the best snorkel or is their no difference between brands.
Is it a big job or can it be done by a handy bloke like myself.
Does any thing under the bonnet have to be moved as there is not a lot of room on the air cleaner side.
Cheers Scoof . :-)
Reply By: Member - Kevin J (Sunshine Coa - Wednesday, Nov 18, 2009 at 18:43
If I may be so bold. Why do you need a snorkel?
1. Do you intend to take your pride and joy into water so deep there is a likelyhood of water entering the system via the ait intake?
2. Do you intend travelling in areas of extreme dust fo extended periods?
If the answer to the first above is no and the second is yes then I suggest you visit your Mitsubsihi dealer and buy a couple of filters to allow you to change the filters at suitable times.
Why anyone would want to have the cost and noise which comes with a snorkel is quite beyond me. Certainly a snorkle will provide some additional protection in deep water situations but where the problem is dust then even the snorkel is no going to be of very much help. Change the filter more often and save the money you would pay for the snorkel.
I might live on the Sunshine Coast but a considerable part of my driving is in the west.
Friend - a western area mailman - blows the aircleaner every few days and changes it every 2/3000kms. His Toyota Ute is coming up to 400000kms and still ticks over well. Uses about a half litre of oil in 5000 kms. Gets an oil change every other Sunday.
Kevin J
AnswerID: 391645
Follow Up By: pmk3 - Wednesday, Nov 18, 2009 at 19:18
Quote;"Certainly a snorkle will provide some additional protection in deep water situations but where the problem is dust then even the snorkel is no going to be of very much help."
I think you'll find the air intake is in the guard & dust pickup is very likely. Having a snorkel will raise the air intake into at least some clearer air.
I used to have a Pajero & wouldn't be without a snorkel because of the position of the air intake.
Each to his own I suppose. Just my opinion.
Scoof,
I did install mine but it was on a NK Petrol engine Not hard job but you want to make sure you have the template placed correctly before you start cutting holes. Sometimes it's easier to have someone fit it for you.
Another problem is there a snorkel available for that model.
I went for the Safari Brand.
Good Luck, PMK
FollowupID: 659574
Follow Up By: Member - Andrew (QLD) - Thursday, Nov 19, 2009 at 07:42
PMK,
Air intake for a NP DiD is just above the radiator....
FollowupID: 659640
Follow Up By: pmk3 - Thursday, Nov 19, 2009 at 08:58
Yeh Thanks Andrew,
I guessed that by the posts....
It used to be in the guard on the NK, Smart move to move it above the radiator for the dust problem but I wouldn't want to cross a deep river without a snokel.
PMK
FollowupID: 659650
Follow Up By: Member - Andrew (QLD) - Thursday, Nov 19, 2009 at 09:17
yeh i answered without reading all the other posts. :) Whoops.
FollowupID: 659654
Follow Up By: Member - Scoot (SA) - Thursday, Nov 19, 2009 at 18:12
Kevin it was recomended that we fit a snorkel for our next trip as we have to cross some rivers and creeks.
Too late once we are stuck with a dead donk. It would also hate to spoil the trip for the rest of our friends coming along as well.
FollowupID: 659718
Reply By: StormyKnight - Wednesday, Nov 18, 2009 at 19:21
I don't get any noise from my snorkel are you talking wind noise from doing 100km/h or wind noise from the air being sucked in or tuned resonances also from the air being suck in @ particular rpms?
If you ever intend to be part of a convoy you will want a snorkel that will alow you to remove the normal head easily & fit a pre-cleaner.
In dessert country you can probably move back out of the dust a fair bit & perhaps 10 cars would still be "in sight" od each other & the UHF would work from tail-end charlie back to the leader, but in the high country for example, you would find even if you stood back that on occasions the dust would just sit in the air & unless you stopped you would have to drive thru it.
PS a snorkel will not improve fuel economy or increase power so keep that in mind too!
AnswerID: 391651
Reply By: OREJAP - Wednesday, Nov 18, 2009 at 19:33
I owned a NP from 2003 to 2009 & after travelling in the vehicle for over 8 months I decided to purchase a snorkel. I decided on the purchase because I felt it would be a beneficial item of equipment. I noticed a significant improvement in the way the vehicle performed also the added protection that if I wished to cross a river and inadvertantly dropped into a deep hole I woild not have water in the motor. Having said that I was also conscious of the fact that snorkels are not the be all and end all in that some "fitted " snorkels have been proved to leak. I had a well known brand fitted but the TJM is best because there is no noise or vibration especially when the Pajero is on boost through the turbo (the new NT model has this situation where it is basically on boost all the time) I direct your attention to the Pajero Club of Victoria where this subject is covered adequately & there is also a full article on this site. Pajeros take air 600mm from the ground above the radiator where patrols & cruisers from the inner guard passenger & drivers side respectively. I would fit a TJM (which I have on my new vehicle) & have it fitted by a reputable dealer in off road equipment like TJM (airtech snorkel) or ARB (Safari snorkel) To test if it leaks after fitting block off the air on top of the snorkel if the motor stops then all is OK if it keeps running (even if it's running rough) take it back to be fixed.
AnswerID: 391653
Follow Up By: cityslicker - Wednesday, Nov 18, 2009 at 21:40
Not sure where you get the 600 mm above the ground, but I just measured mine and come up with 1070 mm above the ground for the intake. I have a slight suspension lift but that probably only accounts for 70 or 80 mm.
FollowupID: 659596
Follow Up By: OREJAP - Friday, Nov 20, 2009 at 14:47
Woops sorry I meant 800mm. 70 to 80mm lift that's the low & high side of 3 inches. Mitsubishi recommend the maximum lift on a Paj is 50mm!! Anyway thanks for the heads up
FollowupID: 659836
Reply By: Member - Kevin J (Sunshine Coa - Wednesday, Nov 18, 2009 at 19:52
As I said in my response. If you intend to traverse deep water by al means fit a snorkel but please think about all the other components which will be getting a ducking. I know that water in the engine is most times fatal but there are more issues that that to look at. By far the biggest problem we currently face is dust.
The Pajero already has argueably the best position eg above the radiator, for the air intake unless you are in close convoy and it seems somewhat stupid to fit a snorkel which while it has the head well above the cabin has an attachment under a guard which is the worst position. Given that most dusty situations are accompanied by rough road conditions the leakage through the under guard fittings can be and usually is substantial.
As was said everyone to his own but from experience even with a snorkel fitted I would still change the air cleaner filter element more frequently if operating in dusty areas.
If you live on the eastern seaboard what did your house look like after the recent dust storms? With the windows closed it still came in to cover everything. You may not have noticed except for the complaints from the Director of Home Affairs.
Kevin J
AnswerID: 391655
Follow Up By: Member - Boobook - Wednesday, Nov 18, 2009 at 20:19
Cheeses u torque owt ov ur arze
FollowupID: 659580
Follow Up By: jdwynn (Adelaide) - Wednesday, Nov 18, 2009 at 21:02
Boobook, I don’t agree with Kevin either but it’s always good to have another view. Otherwise we’d all be conformists, maybe making the same mistakes by never questioning popular opinion. The idea here is if you reckon someone’s wrong, tell us why! Cheers
FollowupID: 659590
Follow Up By: Member - Boobook - Thursday, Nov 19, 2009 at 05:31
You are right jd, I was just going out and posted in a hurry.
Basically one issue is that Pajero's have their air intake above the radiator. They are well known for being susceptible to slurps even in lower height water. Also most people with snorkels report far less dust intake given the height when on dusty roads. My filter for example is much cleaner. Finally, if fitted properly they are water proof. While other parts of am engine might be susceptible to water ( though mostly petrols, not the case of the OP). Any water effect would possibly cause a stall remedied by drying out. In contrast, a gulp of water is fixed by throwing $15000 at your vehicle.
If you do cross water above about 500mm or travel in dusty areas then a snorkel is a probably a good investment. Also some people report a 5 - 10 % fuel economy improvement, though this seems to be vehicle and snorkel dependent.
Finally I am pretty sure that you have to get a Airtec snorkel for that Pajero, I don't think Safari make one.
FollowupID: 659634
Reply By: Wilk0 - Wednesday, Nov 18, 2009 at 21:13
Hi Scoof,
I fitted a snorkel on my 1999 rodeo and it lowered the rpm @ 110km/h by approx 100rpm.
Ive heard it is due to the ram effect. I believe it has lowered the fuel economy as well but I dont have figures to substaintiate it.
Cheers Wilko
AnswerID: 391664
Follow Up By: fisho64 - Thursday, Nov 19, 2009 at 02:40
are you for real or trolling??
At the risk of taking the bait...
If your car is a manual the engine is mechanically connected to the rear wheels by a series of gears. It is simply no more possible than it is for it to take off and fly to the moon.
Even a modern auto which will have a lock up torque convertor has a similar situation.
Okay I took the bait....
FollowupID: 659632
Reply By: StormyKnight - Wednesday, Nov 18, 2009 at 22:37
It lowered your rpm @ 100km/h? Really....
AnswerID: 391682
Follow Up By: Member - Doug T (NT) - Thursday, Nov 19, 2009 at 02:32
That's what I thought too,
FollowupID: 659631
Follow Up By: fisho64 - Thursday, Nov 19, 2009 at 02:41
damn-I just realized why, its a Hiclone branded snorkel!
FollowupID: 659633
Reply By: Member - Kevin J (Sunshine Coa - Wednesday, Nov 18, 2009 at 22:42
Boobook.
Your profile does not indicate your credentials in matters of this nature however you obviously have much more experience than I so I will accept your comments and leave you to provide the expert advice.
Kevin J
AnswerID: 391683
Reply By: Bob of KAOS - Wednesday, Nov 18, 2009 at 22:55
There is no doubt a snorkel will prevent an engine drowning if you go through deep water, and that it may reduce dust ingress.
However, like a lot of 4WD gear (snorkel, hi-lift jack, driving lights, bull bar, winch, long range tanks etc) most of it is of unproven or limited value and purchased more because we like to spend money on our vehicles, rather than because it improves tourability. Ever noticed how most of the most common extras are highly visible?
I wouldn't dream of a snorkel until I had decent tyres and extra spare, dual battery, Engel, UHF/HF radio (unless I lived in the channel country).
AnswerID: 391687
Follow Up By: Member - Kevin J (Sunshine Coa - Thursday, Nov 19, 2009 at 08:08
Bob,
Recently spent time on a property at Windorah - Channel Country. The Paroo actually flows through the holding.
The only snorkels I saw were on Govt vehicles (Police) and tourists. Don't know if that is significant. Also no alloy bull bars and most steel bull bars had full double side rails. UHF is not an option as far as I'm concerned. Would not leave home without it.
Kevin J
FollowupID: 659646
Reply By: Member - Andrew (QLD) - Thursday, Nov 19, 2009 at 08:08
To answer your question scoof without arguing as to whether one should have one or not.....(roll eyes)
I have a Airtec snorkel which sits rather well on the vehicle and seems to be contoured quite well.
I had thoughts of doing it myself, however the extra $100-200 to fit it was a sound investment imo as the shop had done several dozen more fittings than myself :)
Under the bonnet, i believe that they need to cut a small curve in one piece of plastic as well as removing the existing air intake (obviously :))
Image Could Not Be Found
Hope that helps.
AnswerID: 391711
Follow Up By: Member - Scoot (SA) - Thursday, Nov 19, 2009 at 10:26
Thanks for the photo's Andrew,
We are planing a trip with water crossing's , I have a water bra but was a bit worried if I got stuck in the middle of a creek and the car stopped driven forward then the water bra wouldn't be much good as with no bow wave a water bra is not much help.
I'm not a fan of the snorkel but I think I need one now.
Not a fan just because of the looks really bloody ugly things but not that hard to live with.
Cheers Scoot
FollowupID: 659662
Follow Up By: Member - Andrew (QLD) - Thursday, Nov 19, 2009 at 11:37
Be aware that there is a one-way valve at the bottom of the air cleaner box, which i wouldn't bet my life on to stop water coming in if stopped. :) Cleaning that out is sometimes forgotten about as it can be jammed with dead horses etc.
FollowupID: 659671
Follow Up By: Member - Scoot (SA) - Thursday, Nov 19, 2009 at 12:26
Thanks again,
Plenty of live horses under the bonnet. LOL.
FollowupID: 659681
Reply By: Wherehegon - Saturday, Nov 21, 2009 at 13:20
Scoof, my neighbour just had one fitted (safari) a few months back to his 06 DID exceed, had it done by ARB here in Penrith, 4 1/2 hours to fit, brilliant job, great fitment to panels. There is more to it then looks, you need 2 different hole saws, one for inner panel one for outer panel, them alone will cost a nice price. It cost him $250 to fit. He had one fitted due to the fact of the air inlet sitting write on top of the radiator (water was his main concern). NOISE ?? no extra noise in the vehicle, said it goes better, tad better on fuel, said the turbo seems to spool up quicker, Totally happy with his purchase. I fitted my safari to my old lux myself, borrowed saws from work so didnt cost me anything, bit of silastic and was a 10g hilux so wasnt overaly concerned if I stuffed up, the prado I am having fitted by ARB $170, cheaper then the pajero due to easier fitment.Regards Steve
AnswerID: 391982
Follow Up By: Member - Scoot (SA) - Wednesday, Dec 02, 2009 at 17:05
Thanks for your reply ,
Sorry about time taken to reply been away on site working only just got back.
Cheers Scoot . :-)
FollowupID: 661587
