Feidaxin 450A - Settings for duplex use
Submitted: Saturday, Nov 21, 2009 at 14:59
ThreadID: 73896 Views:2688 Replies:3 FollowUps:7
Hi there - I don't know much about radios and have recently purchased set of Feidaxin 450A handhelds. I would like some advice on how to set up the channels for repeaters on the Australian CB network.
My best guess is to set the offset at 00.750 MHz [F]+[8], set the offset value at + [F]+[#], and then in VFO mode go to channel 1-8 and press and hold the # key to set it to reverse frequency.
I assume what this does is set the receive frequency at 0.75MHx higher than the transmit frequency (Hence receiving on frequencies of channels 31-38) when on channels 1-8.
Can someone please confirm I have this right, or advise on how it should be done. Appreciate any assistance I can get.
Regards, Tim.
Reply By: kiwicol - Saturday, Nov 21, 2009 at 20:17
repeator channels only work on channels 1-9 or 10. Using hand helds which have a very poor range due to their power, wont come into their own with repeator channels. Then using any uhf transmittor on duplex transmitting on the higher channels can cause problems and then getting some very un wanted verbal abuse.
Col
AnswerID: 392067
Follow Up By: Tim Owen - Saturday, Nov 21, 2009 at 21:11
I don't plan on using duplex on any channels other than 1-8 (leaving 5 for emergencies of course) - in fact I really only plan in using channel 4 - our local repeater - but will set up all 1-8 for mobile use. Tim.
FollowupID: 660029
Reply By: SteveL (WA) - Saturday, Nov 21, 2009 at 22:20
You have things back to front.You need to receive on the lower channels and transmit on the higher channels.-Steve
AnswerID: 392090
Follow Up By: Tim Owen - Sunday, Nov 22, 2009 at 10:54
Thanks Steve.
FollowupID: 660079
Reply By: Member - Mike DID - Sunday, Nov 22, 2009 at 06:49
"then in VFO mode go to channel 1-8 and press and hold the # key to set it to reverse frequency"
"Reverse" mode is only for listening on the Repeater Input frequency, to check if the other station is in range for a direct/simplex contact.
AnswerID: 392125
Follow Up By: Tim Owen - Sunday, Nov 22, 2009 at 11:08
Thanks Mike. I think I understand.
I now have Channel 31 set to 477.175MHz, the repeater offset at 0.75MHz and the repeater shift at - (Thanks to Steve). I assume this means when on Ch 31 I transmit at 477.175MHz and receive on 477.175MHz - 0.75MHz = 476.425MHz (The channel 1 repeater output freq). If I turn on Reverse mode, I transmit and receive on 477.175MHz - just like if the repeater shift was set at 'same', or the offset value set at 0MHz.
What I'm now unclear on is how the radio knows which channels to apply the offset value to. Is it a 'global' setting for all channels? It appears reverse mode cannot be saved (ie. it turns off when you change channels), and the repeater shift is a global setting.
Tim
FollowupID: 660081
Follow Up By: SteveL (WA) - Sunday, Nov 22, 2009 at 23:32
When on Channel 31 you should be transmitting and receiving on the same channel.When you are on Channel 1 duplex you should be transmitting on + 0.75 Mhz.- Steve
FollowupID: 660165
Follow Up By: Member - Mike DID - Monday, Nov 23, 2009 at 11:46
To operate on Repeater 1 you should have recv on 476.425 and transmit on 477.175.
Can't you just program separate transmit and receive frequencies into a memory for the 8 Repeater channels ?
If you want to operate Simplex on Chan 1, just program another Memory for recv and transmit on 476.425.
FollowupID: 660219
Follow Up By: Tim Owen - Monday, Nov 23, 2009 at 21:11
The offset value and or shift doesn't appear to be channel specific on these radios. Only the reverse mode is channel specific, but this is not a 'saveable' setting.
FollowupID: 660305
Follow Up By: Member - Mike DID - Tuesday, Nov 24, 2009 at 22:32
You are better off NOT using Offset and Shift.
FollowupID: 660448
