AnswerID: 32646 Submitted: Thursday, Oct 02, 2003 at 21:44
Joe
replied:
Hi Taipo
What year FJ is it.
I did something similer a few years ago, put a 3B into a 83 FJ 40. I do remember something about the bell housing/input shaft. I ended up using gearbox from a BJ .You will need engine chassis mounts from the BJ,and grind FJ chassis mounts off. Hint ,put gearbox & engine together with mounts on,then put into vehicle using gearbox crossmember mount to get correct location then drill holes for new mounts in chassis. Get wiring harness for the BJ also,unless you are a auto sparky. Also radiator,battery mount from BJ. Have done a few engine changes over the years,none are simply bolt in drive away. Best thing I ever did for the old girl.
Any more I can help with just ask.
Joe
Reply 1 of 2
