FollowupID: 678553 Submitted:
Friday, Mar 12, 2010 at 20:38
Member - Graham H (QLD) posted:
Well when i was at Mt Compass south of
Adelaide I took particular notice of
temps on the Willunga hill which is quite a long steepish hill.
With the van 2850kg ,the EGT temp went up to 500deg by just over halfway up so I dropped from 4th to 3rd and lifted my foot a bit.
Dropped a little to 475.
THE ENGINE temp had gone up 8 deg only from 80 to 88 deg
The transmission temp which was at 70 at the bottom went up to just over 90 deg
When I got over the top the EGT dropped fairly quickly but it took longer for the engine temp to drop as I was going a bit slow I guess.
The auto took even longer to drop back to 70 again.
This is exactly correct so proves that water temp and exhaust temp dont go up equally.
Nor do they come down the same.
I would be most surprised if the EGT did not drop when you lift your foot as
there will be less gas and less heat, even as in my case when the motor was
still above normal temp.
Just my careful observations.
 Click Image to Enlarge |
| Another Kiwi that flew the coop
Our home away from home
