AnswerID: 2227 Submitted: Thursday, Feb 28, 2002 at 00:00
Porl
replied:
If no-one replies to this look at one in a
shop and underneath or on the side it will have a metal plate or something with the voltage details and the peak amp draw as is required by law - from memory it is about 2.7amps. I run a
waeco with a higher peak amp draw from the back of my Prado with a 120W and 15amp max (or maybe that was 10amps, whatever). The
waeco has a peak amp draw of about 3.7 and I have never had a problem - but i always draw it down to operating temp. on 240v before I go out which may help, and I have never been
on the road with it yet for more than about 4hours at a time. The 24v socket idea is excellent and I will get to doing that soon, more efficient, better for the
fridge, more reliable, marginally less battery drain because of the efficiency etc. But the 120W socket does work and if you have what i think you have it is a marine grade socket that is far better than an ordinary cigarette style socket like found in my gemini.
Reply 2 of 6
