Diff Oil 100 Series
Submitted: Monday, Oct 20, 2003 at 13:22
ThreadID: 7945 Views:2428 Replies:2 FollowUps:1
The question has been asked before no doubt.
Can the same type of oil be used in front / rear diffs (LSD at rear standard front). The oil in my rear is normal oil colour, however the front is a realy dark green silvery colour. Normal????
JD Life is to good to be dead.
Reply By: Phil G - Monday, Oct 20, 2003 at 19:30
Yes. You can use LSD oil in the front diff.
The front diff oil is that colour because the front axle oil seals are becoming worn and the black grease from the swivel hubs is getting in. You may also find that the swivel hub grease is getting more liquid from the diff oil leaking out.
Sooner or later, you need to have the front end serviced and seals replaced.
AnswerID: 34496
Reply By: Hatcher - Tuesday, Oct 21, 2003 at 08:36
Hey Treading Lightly,
Being a LC100 owner myself, I would be interested in knowing how may kilometers you have done in your 'cruiser. It might give me an indication of when to expect replacing the seals in my own truck.
AnswerID: 34559
Follow Up By: Treading Lightly - Tuesday, Oct 21, 2003 at 09:33
Hi Hatche,
We would you believe I have only covered 43K, although the LC100 is a 99 model. Not a lot of work you would agree.
JDLife is to good to be dead.
FollowupID: 24926
