hf radios
Submitted: Saturday, Oct 25, 2003 at 21:46
ThreadID: 8084 Views:2547 Replies:4 FollowUps:3
howdy all
just after a bit of info about the difference between barrett and codan as hopefully will be in the market for a newie soon.when looking in the trading post there always seem to be a lot of codans but not many barrett is this trying to tell me something i tend to lean towards barrett but not to sure of advantages and diadvantages of each.(ps i realise codan is dearer)
steveimagine a 03 gu 4.2tdin the picture
as i am having trouble sizing the picture
Reply By: Member - Bob L - Sunday, Oct 26, 2003 at 17:56
Gob
I think you will find Codan have been around a lot longer and that there are more "old" radios about.
Qmac is another contender.
Cheers Bob
AnswerID: 35164
Follow Up By: GOB member vic - Monday, Oct 27, 2003 at 22:04
bob had a look at the qmac radio seemed okay but did you see the autotune aerial thanks for the reply
FollowupID: 25519
Reply By: Geebung - Sunday, Oct 26, 2003 at 20:57
Gob.....I bought a used Barrett 950 system for $1500 plus postage and mucking about....owes me about $1800 by now.....been back to the factory for a warranty job. Runs very well. I'm in VKS737 and recently joined Radtel too.... I use it a lot and have made a few radphone calls.......seems a winner.
Don't know any modern Codan users...... as you say, they cost quite a bit more but may not offer more. The Barret outback Trav Pack can be picked up retail in Adelaide for $2995 cash.
Hey Bob.... re the Tvan....... been thinking along those lines..... any comment for a prospective buyer ? Dust sealing ? Set up on uneven ground ? Shelter for the kitchen (does it have to be the full awning ?)
Tow ball download ? (my rig has a 100k limit - the Tvan looks front heavy and the specs suggest a lot more than 100k in std setup).
Thanks if you have the time.
Get me outa these suburbs !
AnswerID: 35178
Follow Up By: GOB member vic - Monday, Oct 27, 2003 at 22:02
goodday geebung
i had look at vks site last night at the codan and barrett barrett seemed a bit more user friendly i dont have a phd in hf radio and it almost seems like what u need to run the new codan it had that many bits and pieces would you ever use them any way i will keep looking around thanks for the reply i am also in vks (victor 238)
might catch you on the air when i get my own radio i usually hire when we go away but hopefully soon i will get my own..
steve imagine a 03 gu 4.2tdin the picture
FollowupID: 25518
Follow Up By: Member - Bob L - Monday, Oct 27, 2003 at 22:39
Geebung
Just briefly,the Tvan is easy to tow with economy similar to Shipshape on top. Dust has never been a problem. Uneven ground is not a problem either once you level the wheels , I carry a few wood offcuts for extra support in soft sand etc.
Guestimate 80 kg on tow bar possibly more with 3 jerrycans of fuel offset with 2 jerry cans of water and 70ltrs in tank behind the wheels.
We used the annex for the 1st time this weekend and found it better and easier to use than first thought. For shade or light rain the "sail" is a quicker alternative.
Hope this helps
FollowupID: 25527
Reply By: Peter - Tuesday, Oct 28, 2003 at 09:15
I have just completed a central aust trip with HF radio.
We picked up a 2 hand Barrett 550 with 910 auto tune aerial for $1400.
We are happy with the radio and performace.
After travelling I am glad that we got an auto tune. Makes life so much easier.
There are alot of codans out there and people are happy with them.
I think the question is one of the Fridge type arguments Ours is better.
From my use of barrett 550 and codan 8528 and 9350's they all work well.
As the guy at the radio shop said to me they are all as good as one another. It only boils down to personal choice and what you want to use it for.
Do you want Phone - Both good
GPS connection - Depends on what the recieving radio type is.
Auto tune Both work well But work on differant types of tuning.
As for qmac it is a good unit but from what i hear the auto tune can cause a few issues. This is arround the box that has all the aerial tuning gear in it. If it can be mounted inside the car ok but outside it is prone to water and dust getting in.
It has a 600mm lead.
The unit is 50w which will get you everywhere. For the techo it is 3dB less than the others which is bearly percievable.
For my book a barrett 550 910 or codan 9350 would be good.
My main reason is that they are alot easier to get extra channels added.
AnswerID: 35351
Reply By: Mixo - Tuesday, Oct 28, 2003 at 10:00
Thanks Bob re the Tvan advice. Re the comment above on Qmac.....why buy a 50 watt unit ? ....apparently they are about the same price as the Barrett which can peak out around 125 watts ifn the battery is high on volts.Why I am here looking at this screen ?
AnswerID: 35356
