<span class="highlight">Batteries</span>
Submitted: Tuesday, Mar 01, 2011 at 19:42
PatrolEv
Good Evening,
I am interested in people's opinions on
AGM batteries, in particular what brand people use and how they perform, value for money, etc. I have only used wet cell deep cycle
batteries.
I am interested in using them in a caravan charged from solar to power fridge, lights, TV, etc.
Ev
Reply By: Best Off Road - Tuesday, Mar 01, 2011 at 20:25
I've had two. Lifeline, made in USA and expensive. REMCO, Chinese and cheaper. Lifeline shot after four years, REMCO going strong after six years.
I recommended REMCO to a mate and his is still going great after 4 years.
Jim.
447030
Follow Up By: Member - Keith C (NSW) - Tuesday, Mar 01, 2011 at 20:58
Yep,Remco,my 110ah has been bumping around on the drawbar since,06,still 100%.
719365
Follow Up By: PatrolEv - Tuesday, Mar 01, 2011 at 21:00
Thanks Jim & Keith, appreciate your reply
719366
Reply By: Sand Man (SA) - Tuesday, Mar 01, 2011 at 22:36
Perhaps it depends on which State you are in as to what is available but I am also an investor in the Remco brand of
batteries, which are available for a very competitive price from Whitworth Marine.
However, any battery will suffer from abuse or neglect.
I purchased a second hand camper trailer which had two Remco 80Ah
batteries installed in parallel. I couldn't get the on-board Waeco 12V compressor fridge to run efficiently for any length of time.
On checking, one battery was just over 12 months old and totally stuffed.
The other similar aged battery charged up OK but didn't hold its charge for long.
The result?
I chucked both and bought two new Remco
batteries which will be treated with due respect with the intent of them giving me good performance over a long life, as I believe I can look after them better than the previous owner.
Any battery can be destroyed if drained down sufficiently low for a few cycles and not kept at a full charge between uses.
I also run a 100Ah Remco battery as an auxiliary in the back of the Dual cab ute.
Bill.
447039
Reply By: TerraFirma - Tuesday, Mar 01, 2011 at 23:04
I have had a Remco for 5 years strarting a boat, been brilliant. I also have 4 x Fullriver
AGM's in a marine application that have been faultless after 4 years, early days but with Ctek chargers looking after the maintenance I don't expect any problems and would be surprised if I didn't get 10 years out of them.
447042
Reply By: Battery Value Pty Ltd - Wednesday, Mar 02, 2011 at 08:56
Yes, AGMs give markedly better cycle life than flooded/wet, and are more robust with higher current capability (both charging/discharging) when compared to gel.
Good quality AGMs can be had for just under $1.80 per Ah.
There's more information in my profile.
cheers, Peter
447063
Reply By: CodMaster - Wednesday, Mar 02, 2011 at 11:37
I had the same questions you had before I bought my first
AGM. This site helped me with understanding a lot of it in laymans terms:
http://www.fridge-and-solar.net/agm.htm
I ended up getting a fullriver 105ah and still going strong after many years. Just make sure you look after it and it will serve you
Will
447079
Reply By: Member - Bruce C (NSW) - Wednesday, Mar 02, 2011 at 16:49
Hi Ev,
I agree with all that has been said above.
Looking after the battery means charging with a good multi stage charger such as a CTEK or several other good brands many of which are sold by the EO Member/Traders at competitive pricing. The bigger the battery the bigger the capacity of the charger is a good rule. I use a 25 amp CTEK on my 100 A/H
batteries and that keeps them in good condition. Multi stage chargers can be left connected for long periods of time, ensuring a fuul charge, unlike the old run of the mill 12 volt chargers which would stuff a battery if left on for too long.
If you are aware of thie situation with regard to multi stage chargers then I apologize but this info is as important as which battery to buy..
It may help you to avoid ruining good
batteries with a poor charger.
Cheers, Bruce.
| At home and at ease on a track that I know not and
restless and lost on a track that I know. HL.Lifetime Member My Profile Send Message |
447101
Reply By: Member -Dodger - Wednesday, Mar 02, 2011 at 17:01
We have two fullriver
agm's one going on ten years and the other on 6years both in different applications.
10 year job in vehicle 2nd bat. 6year job in van. both are charged on the run via a 12v dc to dc charger and by solar when stationary.
447105
Follow Up By: garbage - Wednesday, Mar 02, 2011 at 18:09
What are the advantages of having a 12v dc to dc charger rather than a standard alternator charging the battery?
719427
Follow Up By: Sand Man (SA) - Wednesday, Mar 02, 2011 at 18:23
The DC to DC charger boosts the voltage at the battery end if necessary, to overcome voltage drop in longer cable runs, or cable that is not heavy enough.
They can also be of a multi-stage type which is best for good battery health.
Bill.
719431
Follow Up By: CSeaJay - Wednesday, Mar 02, 2011 at 19:03
Garbage
Plus they have the bonus benefit of doubling up as a smart Solar regulator as
well...
719434
Reply By: PatrolEv - Wednesday, Mar 02, 2011 at 17:43
Thank you everyone for the information you have provided, I can always count on this
forum for good info.
Ev
447112
