FollowupID: 723433 Submitted:
Sunday, Apr 10, 2011 at 20:51
oldtrack123 posted:
RE paulnsw posted:
Peter everybody knows except you that temperatures above the manufacturers rating of the fridge will cause the fridge to stop working.
If you cannot understand this "The SN regardless of what you do start dropping their load at 28C the ST at 32C and the T at 36C." there is no help for you.
Peter the only crap here is your ignorance. Ignorant protagonists cannot be helped."
HI Paul
It is obvious from your reply that you do not understand the basic operation of a 3way fridge ,Or what are limiting factors as far as operation goes.
CAN YOU you answer the questions i asked or not??
I & others are talking about practical experience & actual use!!
We are not imagining the results obtained.
just so you UNDERSTAND , NO ONE is claiming a 3way is more efficient,or can cool as fast as a compressor fridge.
IF you have the power source available that is, mains power, or lots of solar , batteries , generator etc then go for a compressor fridge
As I said I have both!!!
What is being argued is your totally incorrect comments re 3ways & their ability.
IT seems your limit of knowledge on 3ways is what you have read , NO PRACTICAL EXPERIENCE
OPEN you mind up a bit, get rid of these preconceived ideas ,
YOU JUST MAY LEARN SOMETHING!!
