No sound
Submitted: Monday, Jul 04, 2011 at 15:44
ThreadID: 87377 Views:2521 Replies:3 FollowUps:3
Under 'Sound and Warnings' I have set the volume control to mid range for 'Master' and 'Guidance'. The voice language is set to English (AU). Yet I have noy got a sound out of my unit.
What can I do to get sound directions?
Reply By: Sir Kev & Darkie - Monday, Jul 04, 2011 at 15:49
George,
What type of unit is it??
Cheers Kev
Russell Coight:
AnswerID: 459162
Follow Up By: Member - George S - Monday, Jul 04, 2011 at 16:56
It is HN5i hema Navigator
FollowupID: 732721
Reply By: Shaker - Monday, Jul 04, 2011 at 16:50
If it is a Garmin, some models have very low volume & at half I doubt if you would hear it.
Have you tried full volume?
AnswerID: 459169
Follow Up By: Member - George S - Monday, Jul 04, 2011 at 16:58
It is HN5i. Hema Navigator
FollowupID: 732722
Reply By: Wilko (Parkes NSW) - Monday, Jul 04, 2011 at 18:14
Hi Goerge,
I'm looking for the mute button on my unit. She's always giving me guidance and warnings as well ; )
Cheers Wilko
AnswerID: 459182
Follow Up By: Member - George S - Monday, Jul 04, 2011 at 19:15
Thanks for your interest. I think I have found the solution.
Q. The device is not making any sounds even though the volume levels are all set at high levels.
A. The FM transmitter function has been enabled. This will send all audio to the FM channel as set in the FM transmitter menu.
To disable the FM transmitter do the following:
From the start up menu tap the Tools icon then FM. If there is a tick and message stating FM function has started, the speaker will be silent tap the tick to disable the FM switch. Sound will now be channelled back through the device speaker.
FollowupID: 732732
