chains
Submitted: Tuesday, Jul 05, 2011 at 20:16
Member - Barry P (VIC)
if driving in snow or mud with chains on ;what do i do about tyre pressures?if pressures are lowered will the chains damadge the tyres? thanks for upcoming replies barry
Reply By: Robin Miller - Tuesday, Jul 05, 2011 at 20:30
You still drop your tyre pressures but not as much.
I.E. Typical road pressure in my car is 32 psi , drop them to 24 with chains.
You don't want chains to cut into good rubber when you hit a hard patch.
Dropping to far can cause chains to flay / come loose.
Note talking bush driving not on Bitumen at a resort , where it can be more important for narrow chain to cut ice and pressures usually kept as were.
459265
Reply By: Crackles - Tuesday, Jul 05, 2011 at 21:48
Reducing tyre pressures is fine with chains fitted as long as you reduce your speed acordingly. Probably wouldn't drop them too much on a light duty road tyre but have found no ill effect on quality mud terrains even down as low as 8 PSI.
Cheers Craig...........
459270
Reply By: Member - Tony (ACT) - Wednesday, Jul 06, 2011 at 07:06
You will find that driving up and back from the ski fields normal pressures are fine (that is if you have to fit chains).
Track driving can be a different matter, as lower pressure can help with floating over snow.
459275
