lubricant compatible with diesel
Submitted: Thursday, Jul 07, 2011 at 14:17
Tim Owen
Howdy - apologies if this is a dumb question. I am about to plumb in an aux fuel
tank including a new fill point. I have the filler hose (Nitrile/PVC suction hose - looks like blue silicone) but getting the fittings into it is really tight - I want to use a bit of lubricant to help get them on - I guess a bit of whatever I use could end up in the diesel.
What is a suitable product? Can I just use a bit of vasoline?
Reply By: Member - Roger T (SA) - Thursday, Jul 07, 2011 at 14:32
hi tim, i think you are on the right track with petoleum gelly or you could use PBR rubber grease as used on brake rubber. if you put it on the fitting not hose it will help and the grease will be pushed away from the inside of the hose. hope this makes sense. as usual i know nothing.
459359
Follow Up By: Member - Toyocrusa (NSW) - Thursday, Jul 07, 2011 at 20:08
Hi Roger. I used rubber grease on petrol fuel injector "O" rings many years ago to make them easier to instal. The petrol turned the grease into a white powder which in turn blocked the filter baskets at the top of the injectors. This took about a week to occur. Have only ever used bearing grease since. Cheers,Bob.
732954
Reply By: Member Al (Sunshine Coast) - Thursday, Jul 07, 2011 at 14:38
Hi Tim, whatever you use should be soluble in diesel fuel to avoid the possibility of a small lump being sucked into the fuel line and injectors.
I would use a smear of engine oil on both surfaces. Any residue will dissolve in the diesel without problems.
459361
Reply By: Member - Captain (WA) - Thursday, Jul 07, 2011 at 15:24
Umm... diesel is actually a light grade oil, ever seen how slippery the floor is near a diesel pump?
Why not just smear some diesel on both ends of the fittings? No contamination issues at all :)
Captain
459364
Follow Up By: Member Al (Sunshine Coast) - Thursday, Jul 07, 2011 at 17:07
Now why didn't I think of that Cap'n?
732933
Reply By: get outmore - Thursday, Jul 07, 2011 at 15:28
rpz or crc?
459365
Reply By: gbc - Thursday, Jul 07, 2011 at 17:35
two stroke oil
459373
Reply By: olcoolone - Thursday, Jul 07, 2011 at 17:37
Any stuff that's slippery, I think you would not use enough of something to cause an issue.
You could use the worst thing "soapy water" and get away with it.... if you used soapy
water you might only use 20ml. and 20ml. (.020Lt.) in a 60lt. plus
tank is not going to make any difference but if you used 1lt. that's a different story.
**DISCLAIMER**
And for the 25 people who are going to jump down my throat about even mentioning soapy
water, I would not advise to us it, it was used an example. ROLF & LOL :)
459375
Reply By: Dave(NSW) - Thursday, Jul 07, 2011 at 18:42
Tim,
Have you tried heating the hose up with hot
water to make it expand & more flexable?
Cheers Dave.
459380
Follow Up By: Tim Owen - Thursday, Jul 07, 2011 at 20:09
Thanks for that one Dave - the hose is going to have to have a tight kink in it, so that could help a lot.
732955
Reply By: david m5 - Thursday, Jul 07, 2011 at 20:30
ky jelly helps me get my hose in
459388
Follow Up By: Outback Gazz - Thursday, Jul 07, 2011 at 21:05
Toyota owners have been using that stuff for years ! ha ha
732956
Follow Up By: fisho64 - Friday, Jul 08, 2011 at 16:32
"Toyota owners have been using that stuff for years"
your right-on the Nissan owners :-)
732985
Follow Up By: Outback Gazz - Friday, Jul 08, 2011 at 21:29
I don't own a Nissan - but as they say
"They only make toyota's so D---h--ds don't buy Nissans"
733003
