steinbauer power module
Submitted: Tuesday, Jul 12, 2011 at 10:09
Member - Dale L (QLD)
Th there is there any one that has the steinbauer chip in there toyota landcrusser v8 cabchassie if so have yo put it on the dyno PS or any other chip
Reply By: snoopyone - Tuesday, Jul 12, 2011 at 11:32
Put a Safari chip in a 2005 TD Cruiser, also put a 3"mandrel exhaust
It went from 145HP to 165.5HP on the dyno but got more from the exhaust than the chip.
Put exhaust on, dynoed it put chip in did it again.
459726
Follow Up By: Member - Dale L (QLD) - Tuesday, Jul 12, 2011 at 12:23
Thanks snoopyone thinking of putting 3" mandrel exhaust
Beaudesert and chip $all most $5.310.00 lot of money it it don't work
733330
Follow Up By: snoopyone - Tuesday, Jul 12, 2011 at 12:29
Had
mine done at AMMS at Sandgate Exhaust was only $1000 fitted V8 may be more of course THey do chips for about $1500.
I think they use Tuneit.
733331
Reply By: TerraFirma - Tuesday, Jul 12, 2011 at 19:31
If you are going exhaust and Steinbauer you won't be dissappointed. I have done my Hilux. You can play with the settings on the Steinbauer and dyno the results. With the exhaust make sure you have the dump pipes ceramic coated,
Beaudesert can do that for you, think it is around $60-80 per pipe. This will reduce the heat factor and present better. With the Toyota V8 and this combo you should end up with a nice torqy drive.
459768
Reply By: birdie - Friday, Jul 15, 2011 at 13:14
I have a 3"sterling exhaust and steinbauer chip fitted to my tdv8. I haven't had it on the dyno but the power difference was awesome. Fuel consumption hasn't changed unless you want to drive it like you stole it.
On Track 4wheel drive centre in
Brisbane supplied and fitted the lot. Steinbauer has the best built in safety features to protect the engine out of all the chips i looked at.
459998
