200 litre blue plastic drums
Submitted: Wednesday, Jul 13, 2011 at 15:29
ThreadID: 87547 Views:9067 Replies:10 FollowUps:3
Our camping and fishing group is thinking of taking petrol in 200 litre blue plastic drums. Does anyone know if these drums are suitable for petrol storage?
Reply By: Notso - Wednesday, Jul 13, 2011 at 16:48
99% sure that they aren't.
They will have the word flammable and symbol on them if they are.
AnswerID: 459847
Reply By: Member - Tony H (touring oz) - Wednesday, Jul 13, 2011 at 16:53
Would probably be a big BLUE if you used then for fuel storage
AnswerID: 459848
Reply By: snoopyone - Wednesday, Jul 13, 2011 at 17:16
Probably would be illegal to fill them at servos as well.
There is a limit on the size of containers used for fuel
AnswerID: 459853
Reply By: Member Al (Sunshine Coast) - Wednesday, Jul 13, 2011 at 17:35
Petrol should only be carried in Approved containers conforming to AS/NZ 2906 which among other requirements has anti-static properties. Otherwise you run a real risk of fire especially in the container quantity size of 200 litres. Any service station properly observing their OHS responsibilities would refuse filling your containers.
Consider also the difficulty and risks of decanting fuel from these containers.
AnswerID: 459856
Reply By: Doomadgee Roadhouse - Wednesday, Jul 13, 2011 at 18:21
no they are NOT suitable, and if you do happen to do it they will melt with petrol in them, i know diesel has been used in em but they leaked as they melted some seals...... but with petrol the whole thing will simply melt away and dump 200L out in one big blob ....
One reason people carry it in lots of smaller containers is that if you get a leak you dont lose everything in one hit ....
Plus what do you need so much for may i ask ???
Joe
AnswerID: 459858
Reply By: Fatso - Wednesday, Jul 13, 2011 at 19:22
My nephew in Mt Isa works on stations & often travels with up to 3 200 l drums in his ute.
Turns out it is a bit of a cop magnet around town at times.
They like to see proof of purchase & the appropriate flammability stickers & of course that they are lashed down.
AnswerID: 459865
Reply By: Peter_n_Margaret - Wednesday, Jul 13, 2011 at 19:29
They are actually made of a similar material to approved fuel drums and they will NOT melt.
Approved petrol containers are made from a cross linked version of HDPE. The blue drums will not be cross linked and therefore will not be as strong. NOR will they be able to withstand the vapour pressure that builds up inside a sealed petrol container, and that is a very serious risk because they will either leak HIGHLY flamable fumes or they will split under the pressure that WILL build up.
Not a good scene!
OKA196 Motorhome.
AnswerID: 459868
Follow Up By: Peter_n_Margaret - Wednesday, Jul 13, 2011 at 19:32
As Doomadgee Roadhouse says, the seals are another matter, and they may fail prematurely.
FollowupID: 733478
Reply By: Member - Howard (ACT) - Wednesday, Jul 13, 2011 at 19:38
JVK,
why wouldnt you just use the old 44 gallon drum designed and approved for petrol storage and cartage?
what advantage would you get from the plastic container other than a miniscule weight saving verse an unproven and unapproved alternative.
Howard
Resigned to Retirement
AnswerID: 459870
Reply By: Tjukayirla Roadhouse - Thursday, Jul 14, 2011 at 10:04
Definitely illegal to fill, and definitely not very smart.
If it is just so you can save a couple of dollars on buying fuel at your destination, or along the way, then that little saving could come at a huge cost. Ie, someone's life.
AnswerID: 459902
Follow Up By: dbish - Thursday, Jul 14, 2011 at 13:23
Other option is lotsof Jerry cans I have 12 X 20 liter jerry cans easier to manage. Some people fish in areas where the only fuel is what you take.
FollowupID: 733511
Reply By: Pushy - Thursday, Jul 14, 2011 at 20:11
JVK,
Don't use them. Apart from the above reasons we have also found that many of bungs leak and can even pop out under pressure.
Most also have a coarse American thread and require a special adaptor($30-$40) to be able to fit any Aust fittings.
AnswerID: 459948
Follow Up By: JVK - Friday, Jul 15, 2011 at 06:32
Thanks everyone. We have abandoned the plan to use these drums.
FollowupID: 733579
