Navman My60T
Submitted: Tuesday, Jul 19, 2011 at 16:41
ThreadID: 87654 Views:3218 Replies:1 FollowUps:2
Has anybody had a Navman MY60T with 4x4 maps installed. If so could you give me an opinion of its worth please.
Reply By: Tonyfish#58 - Tuesday, Jul 19, 2011 at 16:48
I have the MY 75T which has the 4 x 4 Tracks installed. It does not have the 4 x 4 Maps as that is not an option. You would have to unlock & add another program to add maps.
The 4 x 4 Tracks is basic but gives you a line on the map to go to, much the same as navigating streets but without any other info. If you pass a body of water or a lake that appears and that is all I have seen to date.
It also pays not to navigate to an area as it tries to send you on roads that are not there. You would have to preset a route I would say.
For the $ you pay it is adequate, but do not think you will actually see a map on the screen as you will not :-)
Cheers Tony
AnswerID: 460352
Follow Up By: Tonyfish#58 - Tuesday, Jul 19, 2011 at 16:53
Unlocking the MY60T to install Maps
Navman MY75T With 4x4 Tracks not Maps
By the way the 2years of maps is useless, it crashes the unit or deletes some features.
FollowupID: 734025
Follow Up By: Member - Leigh (Vic) - Tuesday, Jul 19, 2011 at 17:59
If you can unlock it as suggested above, load oziexplorer and the Hema maps you will be very happy! A 4 or 8 gig micro card lets you run all of this away from the unit's memory with lots of room to spare. Have 2 navmans set up this way and couldn't be happier with the result. Makes a real cheap versions of the HEMA Navigator with superior local roads mapping. MM me if you wish. Cheers
FollowupID: 734029
