Dometic 3 way Fridge Door opens during travel
Submitted: Sunday, Jul 24, 2011 at 23:34
Nobby
Hi all, I have just returned from my inaugural trip with my new camper trailer and the Dometic fridge door would open after a couple of hours travel on bitumen roads. We checked the door locking clip before each leg of our trip and it appeared to be fully en-gauged. In the end we used electrical tape to hold the door closed. When we were parked up it holds ok. Could I have a faulty model or is this normal and I have to use velco or something similar to hold the door when travelling? Has anyone had any experience and advice they wish to share with these fridges before I go back to the supplier?
Reply By: Member - Rod N (QLD) - Monday, Jul 25, 2011 at 05:46
Yes this seems to be common. I made a velcro strap to help hold
mine closed. See here for recent discussions
Fridge door lock I have seen mention of putting a washer under the bottom hinge on a few forums.
460836
Reply By: white pointer - Monday, Jul 25, 2011 at 08:28
hi
nobby we had the same problem and because of limited space around the fridge in our van,a hook and eye latch was all we could install.
there is a childproof lock for cupboards available from pharmacies which may help.
what are the manufacturers thinking when installing a useless latch on a fridge made for vans etc.? regs.
phil
460846
Reply By: Shaker - Monday, Jul 25, 2011 at 09:16
If it is a new camper you should refer the problem back to the camper manufacture, the onus is on them to make sure that the accessories that they fit are suitable for the expected application.
They, in turn will take it up with Dometic or their supplier.
460849
Reply By: Member - Keith C (NSW) - Monday, Jul 25, 2011 at 09:50
Nobby,We had the same problem with ours, I drilled a small hole thru the top bracket that holds the clip and into the top frame of the door, while the door is closed tight of course, then used a long shaft pop rivet to drop into the hole,I then used a piece of fine chain and a tiny screw to fix the rivet to the cabinet just above the door,just drop it in before you move off, Looks tidy and does the job.
Regards Keith
460851
Follow Up By: Member - Tony S (WA) - Monday, Jul 25, 2011 at 19:38
Yes same problem.
You have to take the piece on the top of the door and pack it with a piece of fine cardboard. I.e. weeties packet or something similar. Problem solved.
734595
Reply By: Member - Frank P (NSW) - Monday, Jul 25, 2011 at 20:23
My off-road van manufacturer uses a different brand of fridge but I magine the problem is the same.
The van manufacturer installs as standard two of those elastic loops used on ute tonneau covers. They are placed on the side of the fridge, one toward the top of the door, one toward the bottom, to hold the door closed, primarily while travelling.
After a while the standard latch tends to not latch any more. We have to pack under the bottom hinge to correct the door sagging a little and that fixes the standard latch. But we still need the elastic loops while travelling.
In effect the standard latch is used only while stationary on site.
Frank
460914
Reply By: Member - john y - Tuesday, Jul 26, 2011 at 14:00
We had the same problem which was solved by buying a plastic child proof fridge lock from target/k mart for about $10.Stap section sticks onto the top section of the fridge fascia and latch sticks on the door.Problem solved
460978
Reply By: Member - The Bushwhackers -NSW - Tuesday, Jul 26, 2011 at 21:50
G'day
Nobby
We bought a new A'van ... same problem as you (and Dometic as
well).
We got the service guy from our A'van dealer out twice to have a go at fixing it. The last effort seems ok, but I haven't had the chance to go anywhere since it was 'fixed'.
The 'solution was packing up the bottom hinge with washers, as mentioned earlier. As far as I am concerned, it's a bloody joke, but not funny if you have spilled food (milk in our case) all over the floor when you stop and set up.
A'van have gone to a different brand fridge, only a couple of months after we bought ours.
Cheers, Dave
461026
Reply By: BrownyGU - Sunday, Jul 31, 2011 at 11:55
Nobby,
Same same with our 3 way dometic, My wife just puts a $2 coin in behind the plastic latch....works a treat!
Cheers.....Browny
461389
Follow Up By: Nobby - Monday, Aug 01, 2011 at 23:10
Browny and everyone above who replied, thanks for the many options. I agree the mess of fridge contents on the floor is something that one can live without. I will give them a go and return to enjoying my new camper.
Nobby
735239
