80 channel programming
Submitted: Thursday, Jul 28, 2011 at 09:12
ThreadID: 87826 Views:15313 Replies:4 FollowUps:9
This is from UHF CB Australia site.
Unlocking the Uniden UH076SX-NB UHF CB radio
Turn on the power by turning the power knob clockwise
Press the channel up button until it reads channel 39 and wait 3 seconds
Turn the power off by turning the power knob anti-clockwise and wait 4 seconds
While holding down the (TXP) & (MON) buttons, Turn the power knob clockwise to turn the power on
Check the channel range to see if channels 41 to 80 appear
If channels 41 to 80 fail to appear repeat steps 1-5
Unlocking the Uniden UH710SX-NB / UH720SX-NB UHF CB radios
While holding down the (TXP) & (SCAN) buttons, Turn the power knob clockwise to turn the power on
Icom 400Pro UHF CB radio
The Icom 400Pro is 80 Channel Upgradeable however you will need the programming software and programming lead
(Please do not ask for software as we do not distribute any software)
I would like to thank to Justin (VK1FXJC) for making the file available to everyone
Download Job File Here
Unlocking the Uniden UH7760NB UHF CB radio
View & Comment on this video on YouTube
Unlocking the Uniden UH078SX-NB UHF CB radio
While holding down the (TXP) & (CALL) buttons, Turn the power knob clockwise to turn the power on
Unlocking GME UHF CB radios
Dealer Upgradable Radios
The following models of radio are dealer upgradable when containing the correct serial number prefix
Radio Model Number
TX3200, TX3420, TX3440
Serial Number Prefix
012, 101, 102, 103, 104, 105
User Upgradable Radios
The following Models of radio are user upgradable when containing the correct serial number prefix
Radio Model Number
TX3100, TX3340, TX3500, TX3510, TX3520, TX3540, TX4400, TX4600*
012, 101, 102*, 103*, 104*, 105*, 106*
*Serial number prefixes apply to the TX4600 only
GME UHF CB user upgrade instructions
Select Channel 7
Switch the radio 'Off' then 'ON' again
Select Channel 23
Select Channel 39
Select Channel 15
Select Channel 31
Unit should display channel 80 if successful, if unsuccessful try again from step one
Show us your support and spread the word by
Liking us on Facebook and following us on Twitter
RA.
Reply By: SteveL - Thursday, Jul 28, 2011 at 12:33
The Icom IC-41S is also upgradeable, but you need the programming software, adjusting software and a programming cable (different cable to 400pro). One dealer I spoke to quoted $60 to do it, if you don't want to DIY.
AnswerID: 461141
Reply By: Kanga1 - Thursday, Jul 28, 2011 at 14:08
Hi Rockape, do you know if the GME TX 3800 radio is upgradeable to the 80 channel, I have had some some extra frequencies (Screen says channel 50, 51, and 52.) On it now for Motorsport events and some other work done to it, the unit has been excellant and I would like to keep it. Any Info on the 80 Ch upgrade would be helpful, cheers, Kanga.
AnswerID: 461154
Follow Up By: SteveL - Thursday, Jul 28, 2011 at 14:40
The GME TX 3800 is upgradeable as it has enough channels and will do narrow band RX and TX.
FollowupID: 734854
Follow Up By: Member - Christopher P (NSW) - Thursday, Jul 28, 2011 at 15:20
Hi Rockape, do you know if the handhelds like the TX650 is upgradeable to 80 channel's?
Thank you for any info?
p.s. i willl also do a google search as well.
FollowupID: 734857
Follow Up By: Member - Boobook - Thursday, Jul 28, 2011 at 15:25
If you join this group, you will find all you need.
TX3800 group
I put the 80 channel file in there. It runs wideband for channels 1 - 40 and narrrowband for channels 41 - 80 for better compatibility with old UHF's.
You might even find some software for a PC too.
Also you can buy a cable on ebay if you don't have one.
FollowupID: 734858
Follow Up By: Member - Christopher P (NSW) - Thursday, Jul 28, 2011 at 16:30
Thank you
FollowupID: 734862
Follow Up By: Kanga1 - Thursday, Jul 28, 2011 at 19:38
Thanks Steve, the radio is too good to replace, I'll get the extra frequencies put into it. All the best, Kanga.
FollowupID: 734877
Follow Up By: Member - Boobook - Friday, Jul 29, 2011 at 09:26
Sorry Christopher, I was following up on Kanga1's original reply, that info is for the 3800.
FollowupID: 734906
Reply By: Diesel 'n Dust - Thursday, Jul 28, 2011 at 16:32
On ya Rockape!!
Looks like I may not have to buy another UHF afterall!!
I bought a TX4400 a couple of years ago and I think I can add channels ( but this was before my knowing of the 80 channel change ).
I guess I must check the serial number!
Matthew
Matthew Clements
I just love the Pilbara!
1HDJ79 RV
AnswerID: 461165
Follow Up By: patsproule - Thursday, Jul 28, 2011 at 17:48
AFAIK only recent TX4400's can be done.
FollowupID: 734869
Reply By: landseka - Friday, Jul 29, 2011 at 16:41
Why don't manufacturers be honest and say that they are a 75 channel UHF, not 80 as they advertise as 5 channels are locked and cannot be used?
Cheers Neil
AnswerID: 461265
Follow Up By: olcoolone - Friday, Jul 29, 2011 at 22:12
Well they should be called 79 channel radio's as only one channel is missing.
FollowupID: 734969
Follow Up By: Member - Boobook - Saturday, Jul 30, 2011 at 08:16
They are called 80 channle UHF's because there are 80 channels.
However there are 3 channels reserved for future use at the moment leaving 77 Channels
The missing ones are 61, 62 and 63 as guard channels for channels 22 and 23 which are for data only.
FollowupID: 734977
