CSR water supplies
Submitted: Friday, Jul 29, 2011 at 11:48
Member - hydeaway
Can anyone who has recently travelled the Canning recommend how much
water to carry with you. Do most of the bores still have usable
water. Can you use this for washing and carry only
drinking water
Reply By: Alan S (WA) - Friday, Jul 29, 2011 at 13:26
Having just done it, I carried 140lt between two of us and had no problem. I could have carried less.
Wells that we filled up at were
46
Water was good and drinkable
33 Very good
waterGeorgia Bore excellent
After that I went through to
Wiluna with out filling up again.
Others in our party carried only 60 ltr between couples and also had no problems.
Well 26 was undergoing restoration when we went through and may be producing good
water again
461241
Follow Up By: Member - Duncan W (WA) - Friday, Jul 29, 2011 at 19:47
Alan & others
Well 26 has good
water to 4m deep in th ewell and very potable.
I'll post up a report tomorrow from TCWA regarding the restoration work undertaken a fortnight ago.
734951
Reply By: Crackles - Friday, Jul 29, 2011 at 14:16
Water usage on the Canning is a personal thing that you should work out from previous
camping experience as there can be a huge variation between different people. I've heard figures as high as 10L per person per day where for me I'd average less than 3. For a winter run 120L for 2 people would be acceptable on a 16 day trip.
There are plenty of opportunities to top up
water for cleaning & washing which I'd assume would be listed with the permit or in Eric Guards Book. Some is good enough to drink although worth boiling 1st. (don't rely on it as occasionally
water is fouled by dead animals)
Water usage can be minimised by planning meals that don't require much to
cook or clean, share washing in the group, use paper plates etc. If getting off the beaten track, travelling in Summer or are on your own then additional
water in case you're stranded would be wise. Allow some for windscreen washer & a complete radiator change.
Some friends that just left for the Canning had over 200L on board (for 2) which I see as excessive adding unnecessary weight to what was already an overloaded car.
Cheers Craig.............
461249
Reply By: andoland - Friday, Jul 29, 2011 at 14:48
We went through in June - 2 adults and 2 children - and had 75 litres
water capacity. Our 55 litre
tank was reserved for
drinking water and the 20 litre jerry can for washing
water.
We obtained
drinking water from
well 6,
georgia bore (
well 22) and kunnawarritji community. The
water at
well 33 was also drinkable.
As
well as the above we got washing
water (i.e.
water that was good enough for dish washing and showering but we would not drink) at Durba Gorge and
well 49. There may have been one or two other wells but I can't remember.
People we came across travelling in the opposite direction had removed a dead snake from
well 46 so we did not take any
water from this
You should be aware that most of the wells are dry and/or no longer exist, e.g. are just a depression in the ground.
Well 24 was full of
water, so full that it was overflowing and surrounded for 5-10 metres and the
water had lots of crud in it so we did not even bother with this for washing
water.
Well 25 was in the middle of a late and I presume when this dries out enough to access the
water will probably be salty.
461254
Reply By: Member - hydeaway - Friday, Jul 29, 2011 at 16:46
Thanks for comments.
461266
