Mt Samuel to Jackie Junction
Submitted: Friday, Jul 29, 2011 at 12:36
Member - Ralph K (WA)
Am travelling the Gunbarrel late Sept/ early Oct and was wondering if I should turnoff at Mt Samuel and take the
Heather Highway to the
Great Central Road or continue on to
Jackie Junction and then down.
Anyone have any advice?
Reply By: greybeard - Friday, Jul 29, 2011 at 12:47
Probably a good idea to check your permit conditions. That may be the deciding factor.
461233
Reply By: susan l - Friday, Jul 29, 2011 at 13:18
yes,it's a good idea.
461238
Reply By: Member - Ralph K (WA) - Friday, Jul 29, 2011 at 13:43
That section of the Gunbarrel is closed (not open - sacred land) however I saw a DVD recently on the
Gunbarrel Highway -
Wiluna to Warakurna where they went through to
Jackie Junction and down. The DVD was dated 2006 so maybe there has been changes in the past few years.
Thanks for your input.
461243
Reply By: rocco2010 - Friday, Jul 29, 2011 at 13:54
Gidday Ralph
Travelled west from Jackie Junctiion to
Wiluna a few weeks ago. The track between
Heather Highway intersection and
Jackie Junction has many, many long washed out sections. Basically the track has become a
creek in many
places. Most are negotiated easily with care and there are diversions around the worst bits. But it makes for slow going. Then again, slow going through a washout may be preferable to going a bit faster over corrugations.
Rocco
461246
Follow Up By: Member - Ralph K (WA) - Friday, Jul 29, 2011 at 14:10
Thanks Rocco,
How did you organise permits as I have been advised that that section oif the Gunbarrel is cloised?
Ralph
734921
Follow Up By: rocco2010 - Friday, Jul 29, 2011 at 14:36
Cant help with that info Ralph as I was in a tagalong and the permits were organised by others.
734928
Reply By: Member - Stephen L (Clare SA) - Friday, Jul 29, 2011 at 14:05
Hi Ralph
As you are aware, you have two options and both are as good as each other. The actual road down from
Jackie Junction to
Warburton is a closed road and the actual track that you need to take is around 30 kilometres west of
Jackie Junction.
If you are not running moving maps, eg Ozi, this turn off is harder to find and is less travelled compared to the
Heather Highway. This track will bring you about 1 kilometre east of
Warburton and a simple matter of turning right when back on the Great Central and you are then in
Warburton. If you take the Heather, it is a
well defined track and when you hit the Tjirrkarli turn off, it is then a super Highway all the way down to the Great Central.
Either way it is great country and have a great trip.
461248
Follow Up By: Member - Ralph K (WA) - Friday, Jul 29, 2011 at 14:18
Thanks Stephen,
Can see the track you mention but I think I might play it safe and do the
Heather Highway.
I'm sure we'lll have agreat trip.
Ralph
734923
Follow Up By: ricochet - Saturday, Jul 30, 2011 at 15:36
recently travelled the track that comes out just east of warbo you mentioned. it is in good condition and not a bad drive.
735005
Reply By: equinox - Friday, Jul 29, 2011 at 21:31
Hi Ralph,
You could try the
Warburton North Road, from
Jackie Junction to
Great Central Road. A bit different, follows the original
Gunbarrel Highway and gets you a bit closer to
Warburton.
461297
Follow Up By: Member - Ralph K (WA) - Saturday, Jul 30, 2011 at 09:24
Looks good,
might give that a go.
Thanks Alan
734985
