earthing an inverter
Hi All.
I assume this question has been asked a dozen times, but here goes once more.
How/to where do you earth your inverter?
We will be using it for first time, and don't want to try and error with 240 Watts.
Thanks in advance Robert
Reply By: Member Al (Sunshine Coast) - Sunday, Jul 31, 2011 at 12:09
Robert, if it is a modern inverter (and I assume it is) then it is 'Fully Isolated' and does not require earthing of the 240v output. Nor should the output be 'earthed'.
If the inverter is provided with an 'Earthing' terminal that only 'earths' the housing and this can be beneficial if the inverter is producing any RF (radio) noise. Simply connect that terminal to the vehicle body if needed. The wire need not be very heavy gauge. But if you are not experiencing radio noise then don't bother.
AnswerID: 461392
Follow Up By: escapesilv - Sunday, Jul 31, 2011 at 14:05
Hi Al
Thanks for your information. Yes it is a fully Isolated inverter, so I will leave as is and earth only if RF noise appears.
Thanks again.
Robert
FollowupID: 735064
Reply By: Member - Serendipity(WA) - Sunday, Jul 31, 2011 at 16:04
I have an issue with my inverter which may be an earthing problem. When I have the laptop plugged into power from the inverter I cannot use the track pad mouse.
Looking on forums about this and it is an earthing problem. Of course the forums don't know I am using it from an inverter.
All I did was to just let the laptop charge up and then use it later with no problems.
So if I run a wire from the inverter to somewhere on the camper frame it would be earthed?
Serendipity
AnswerID: 461409
Follow Up By: snoopyone - Sunday, Jul 31, 2011 at 16:28
Buy a Converter to UP the 12V to whatever your lappy runs at (usually19v) and you wont have any more trouble.
No need for an inverter to up it to 240 then the power supply to cut it back again
FollowupID: 735072
Follow Up By: Member Al (Sunshine Coast) - Sunday, Jul 31, 2011 at 16:52
Serendipity, I cannot see how it could be an earthing problem as your laptop power supply module would fully isolate the laptop from the inverter. Maybe an RF issue but I doubt it.
Connecting the inverter body to the camper frame probably would not eliminate any RF issue but you could try it.
Try this: Connect the inverter to the laptop via its power module and operate the computer. Try the track-pad and if it does not work, leave everything connected and leave the computer running then simply switch off the 12v input to the inverter. If the track-pad now works it suggests an RF interference problem.
But as Snoopyone says, a 12v-to-computer power module from Jaycar or Dick Smith etc may be a better solution. Or stick to simply recharging as you have been doing.
Sorry I can't be more help without actually having hands-on.
FollowupID: 735074
Follow Up By: Battery Value Pty Ltd - Sunday, Jul 31, 2011 at 18:52
Hi Serendipity,
touchpads can be temperamental if other than the original power supply is being used.
Because they depend on the capacitive coupling between your fingertip and a virtual ground, any RF from either the non standard power supply, or like in your case from the inverter can confuse the signal generation circuit (your body acts like a receiving antenna for this RF noise).
You can try to eliminate or at least sufficiently attenuate the electrical noise coming from your fingertip by doing the following:
put some layers of thick rubber sheeting under your inverter so that it's not in close proximity to the chassis.
If that doesn't fix it, put some aluminium foil under your laptop, and touch this foil with our arm when working the touchpad.
If that still doesn't help, you can try and establish a galvanic connection between laptop ground and the foil. You could roll some foil between your hands into a thin conductor and stuff it around the VGA socket and make the other end touch the foil - keeping one arm/elbow on the foil while touching the pad should finally make it work.
cheers, Peter
FollowupID: 735082
Follow Up By: Dennis Ellery - Sunday, Jul 31, 2011 at 20:37
Googly gloop - how do you make some so simple, so complex?
FollowupID: 735097
Follow Up By: Member - Serendipity(WA) - Sunday, Jul 31, 2011 at 20:38
Hi Guys
Thanks for the answers. The laptop has a uni body of all aluminum housing and I only use the original OEM power pack.
The inverter is attached to a fibreglass panel in the camper with no metal connection.
It sounds like a RF issue. This has not been a major problem so I will just continue with charging the laptop and then using it.
Of course one day I will get down to JayCar and pick up a 12v supply for a laptop.
Serendipity
FollowupID: 735098
Follow Up By: Dennis Ellery - Sunday, Jul 31, 2011 at 20:38
FollowupID: 735099
Follow Up By: Member Al (Sunshine Coast) - Sunday, Jul 31, 2011 at 23:34
I think it takes great skill Dennis,...... and much practice. LOL
FollowupID: 735123
Follow Up By: Member - The Bushwhackers -NSW - Monday, Aug 01, 2011 at 14:50
And a lot of knowledge!.
Serendipity, I went on eBay, searched for 'laptop cigarette lighter charger', with the model of my laptop in there, and got a charger (90 watt) specifically for my particular laptop. Think it was around $20. Jaycar will cost a bit more than that (maybe $90, as I saw at Dick Smiths). 90 watts is sufficient power to allow you to use and charge the laptop at the same time. Less than that may not charge the battery if you are using the laptop (ie moving map), depends on your supply requirements.
Cheers, Dave
FollowupID: 735161
Follow Up By: snoopyone - Monday, Aug 01, 2011 at 16:05
You need at least that and about 6000ma as well.
I bought a 3500ma model and it would just power the netbook and then run out of oomph when doing anything
I upgraded to the Projecta 6000ma model and have had no more trouble
I actually took the battery out of mine as it only ever ran on the power supply
FollowupID: 735177
