Question: Trailer Wiring Diagrams
Submitted: Tuesday, Aug 02, 2011 at 20:44
N/A
this is just plain stupid i have searched for 3 hour's and still no closer to finding out about 7 wires going to a 6 prong plug...?????/
THAT IS A SIMPLE QUESTION I THINK ? ONE LAST FRIGGIN TIME (SORRY I AM VERY bleep OFF ) HERE GOES : 7 WIRES ON MY PROWLER TRAILER MY TRUCK HAS A 6 ROUND PLUG I LIKE A FOOL CUT THE 7 FLAT BLADE PLUG SO HERE I AM WITH 1RED/2YELLOW/3BLACK/4BLUE/5GREEN/6WHITE/7BROWN.
NOW CAN SOMEONE PLEASE PLEASE TELL ME WHERE ON A 6 PRONG PLUG DO I PUT 7 WIRES..? PLEASE PLEASE PLEASE
I MUST MOVE THIS TRAILER TODAY 7 WIRES TO A 6 PRONG ROUND ...??? HELP HELP PLEASE I NEED THIS ANSWER PLEASE..? mark.excellence@gmail.com
Reply By: Member - Toyocrusa (NSW) - Tuesday, Aug 02, 2011 at 20:50
Hi.
Brown = Tailights
Red = Stoplights
Yellow = Left Blinker
Green= Right Blinker
White = Earth
Balck is the odd wire
Cheers,Bob
461642
Follow Up By: blue one - Tuesday, Aug 02, 2011 at 20:51
Black = Reverse
735348
Follow Up By: blue one - Tuesday, Aug 02, 2011 at 20:52
I don't use it.
735349
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Aug 02, 2011 at 20:54
Reverse not normally required on a trailer.
735351
Follow Up By: snoopyone - Tuesday, Aug 02, 2011 at 21:15
I would post a pic but I cant so a Google search on "trailer wiring diagrams" would have revealed this amongst a lot odf others
http://www.lion.net.au/TRAILER_WIRE/Wiring%20Diagram%20for%20Plugs%20Bases.pdf
735354
Follow Up By: snoopyone - Tuesday, Aug 02, 2011 at 21:18
The article to the right of your text in THE 3 THREADS you have posted also provides the answer
735355
Follow Up By: garrycol - Wednesday, Aug 03, 2011 at 09:58
Blue - trailer brakes
735384
Reply By: Roughasguts - Wednesday, Aug 03, 2011 at 08:43
Easy..... go out and buy matching seven pin plugs.
461676
Follow Up By: brianc - Wednesday, Aug 03, 2011 at 09:55
And the pin numbering / allocation is usually on the packet.
735382
Reply By: TerraFirma - Wednesday, Aug 03, 2011 at 12:14
If you have been searching for 3 hours and haven't found anything, that tells me you are going about it the wrong way. Just put a 7 pin plug on the other end and wire it as per the instructions, shouldn't get any harder than that. If you can't deal with plugs buy a trailer board from Supercheap for $70 and that includes lights, choice of plugs and your good to go.
461690
Reply By: DesF - Wednesday, Aug 03, 2011 at 16:41
Just type " 7 Pin Plug Wiring " into Google and the first link has all the trailer plugs wiring setups with coloured pictures,
I have never seen a 6 pin plug in 26 years of mechanics.
Cheers Des.
461720
Follow Up By: snoopyone - Wednesday, Aug 03, 2011 at 17:59
Open the article in the right of the OP and you will see some. They do exist
735427
Follow Up By: DesF - Wednesday, Aug 03, 2011 at 18:57
Well I'll Be!. You learn something everyday. cheers Des.
735437
Reply By: Road Warrior - Wednesday, Aug 03, 2011 at 17:07
