Kakadu end of April
Has anyone been to Kakadu at the end of April? I know the climate gets drier and cooler later on but it isn't possible to be there later. I'd be interested in knowing whether anywhere could not be visited then. According to everything I read, the wet has finished by late April and the roads are passable.
There's 4 of us - 2 couples. We're thinking of renting a motorhome from Darwin, as the cost of guided trips work out to be very expensive with the exchange rate with the British pound is so dreadful now. What places will we miss by not having a 4X4?
Diana
Reply By: get outmore - Friday, Aug 19, 2011 at 06:00
depends on the wet. last wet was massive but generally late april should be a very good time to visit as it has cooled down a bit, stopped raining and all the rivers and floodplains should be starting to drain off.
alot of the park is sealed/good roads and that early i reckon you will find the 4x4 spots will still be closed anyway
you might miss out on a bit but you will still see plenty and you should miss the hight of the tourist activity
AnswerID: 462918
Reply By: ao767brad - Friday, Aug 19, 2011 at 16:59
As the other reply said it depends on the year, we went through in early May this year and heaps or dirt roads were still closed. Camp grounds all open but alot of damage to roads in Kakadu and Litchfield. If able hire the landcruiser troopy conversion so you can get into some of the better spots as from memory the rental agreement on the motorhomes state NO DIRT ROADS or your insurance is null and void.
AnswerID: 462990
Follow Up By: Diana d2 - Friday, Aug 19, 2011 at 17:07
Thanks for this. Would we miss some of the best places by being restricted to not being able to drive on the dirt roads?
Diana
FollowupID: 736795
Follow Up By: Motherhen - Friday, Aug 19, 2011 at 20:03
Hi Diana
The bitumen road is basically a big loop through woodlands. Apart from getting into Cooinda where the Yellow Waters boat cruise is (a must do), and perhaps the road into Nourlangie Rock Aboriginal rock painting site, most of the side roads are dirt, although the only ones we found with real four wheel drive need are the tracks into Jimjim Falls and Twin Falls. Access to these is usually a bit later when the water subsides and by that time the flow over the falls is very small. Taking a flight over these falls when in full flow would be spectacular.
FollowupID: 736827
Follow Up By: Diana d2 - Friday, Aug 19, 2011 at 20:11
Thanks. I guess for us, it's not whether a 4 wheel drive is necessary but whether the rental agreement on a motorhome allows us to go on the dirt roads, which I understand they don't.
I'm afraid with the awful exchange rate of British Pound which I don't think is going to change dramatically for the better for a long time, a flight is probably out of the question.
We'll have to give it some thought.
Diana
FollowupID: 736829
Follow Up By: Kelvo - Friday, Aug 19, 2011 at 22:04
Hi Diana,
As you said 'normal' motorhomes are not allowed of sealed roads, so your only real option is a 4x4.
I have used http://camperworld.com.au/4WD_bush_cruiser.html in the past, but renting out of Perth. They also have a depot in Darwin. Their 4x4's are allowed on dirt tracks, but still have conditions.
"Limitations of Use
It is a condition of the Rental Agreement that vehicles cannot be driven in certain areas of Australia. For your own protection, please ask. For example, 4WD Campers may only travel to the following areas with the written permission of Camperworld:
Simpson Desert, Strzelecki Track, Gunbarrel Highway, Cape York, the Bungle Bungles, Oonadatta Track, Birdsville Track, Tanami Track and the Gibb River Road. Permission being granted is subject to weather conditions.
The distance to nominated destinations in relation to the length of the hire period will also be considered. Our vehicles are not permitted on the Canning Stock Route, the Lost City in Lichfield Park and the Telegraph Road section of the road to Cape York. Camperworld reserves the right at its sole discretion to restrict vehicle movements in certain areas due to adverse road or weather conditions, and the distance to nominated destinations in relation to the length of the hire period."
I have no affiliation to them, just a satisfied past customer!
FollowupID: 736844
Follow Up By: Diana d2 - Saturday, Aug 20, 2011 at 01:07
Thanks for this. Although the 4WD Bush Cruiser would not be suitable for 4 adults to sleep in, perhaps that and a rented tent might be the answer. I have emailed them to get a quote and check whether they do rent out of Darwin.
Diana
FollowupID: 736853
Follow Up By: Motherhen - Saturday, Aug 20, 2011 at 11:21
Hi Diana
Do a search for other rental companies. I have seen various types of Landcruiser based hire campers, including one the had a sort of pull out annex and looked quite roomy - but that was some years ago.
Another alternative is to go on one of the adventure tour coaches into the off road sights - no idea of costs though. If they went out of Cooinda (or at nearby parks campground Mardugal if you didn't need power) you could stay there and drive to the easy places.
Mh
FollowupID: 736883
