LED Bull Bar lights
Submitted: Monday, Aug 22, 2011 at 20:41
ThreadID: 88626 Views:5476 Replies:2 FollowUps:10
Good evening learned ones, I have just replaced the LED indicator/park lights in my Bull Bar with another pair from a different manufacturer (I broke one of the first set with an animal strike). These new LED park/indicators are giving me radio interference when they come on making the Wireless unlistenable :-( . Any clues on how to suppress the static? Can I solder something into the Earth wire to stop it? Any advice appreciated. Kanga.
Reply By: Member - Andrew (WA) - Monday, Aug 22, 2011 at 22:05
I don't know but these guys may be able to help...
http://www.brightlightautoparts.com/index.html
I'm thinking of changing the park/indicator lights in my bull bar to LED too. Where did you get yours???
AnswerID: 463297
Follow Up By: Kanga1 - Monday, Aug 22, 2011 at 23:23
Hi Andrew, the first set I got from ARB in Mandurah, but they don't stock them any more, I got these new ones from eBay a couple of weeks ago. Just had a look on eBay to contact the guy I bought these from and see if there is a fix for the problem, there is another seller selling the same LEDs that I had in the first place that didn't cause any problems, these look like the the first set.
www.ebay.com.au/itm/380345266929?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
These are the ones that are causing RF interference
http://www.ebay.com.au/itm/270704387309?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I have bought gear from Bright light auto parts before without problems, will give them a shout tomorrow. Cheers, Kanga.
FollowupID: 737104
Follow Up By: Member - Andrew (WA) - Monday, Aug 22, 2011 at 23:35
What happened to the set you got from ARB?
FollowupID: 737105
Follow Up By: Member - Andrew (WA) - Monday, Aug 22, 2011 at 23:37
woops...animal strike....
So was the original LED set from ARB the same as these types in Ebay or different???
FollowupID: 737106
Follow Up By: Kanga1 - Tuesday, Aug 23, 2011 at 00:02
The first ones I got from ARB look to be identical to these
Site Link
with no interference, cheers, Kanga.
FollowupID: 737110
Follow Up By: Member - Andrew (WA) - Tuesday, Aug 23, 2011 at 00:05
and did they fit straight into the existing position...screw holes etc? What about the wire connection..same fitting?
FollowupID: 737111
Follow Up By: Kanga1 - Tuesday, Aug 23, 2011 at 00:06
You may be wondering how I have managed to get these web page link/pages in three different ways. So am I, ???? Confused Kanga.
FollowupID: 737112
Follow Up By: Kanga1 - Tuesday, Aug 23, 2011 at 00:10
The screw holes were about half a mil different and the wires just finish with no connector, you solder them into your light wires. Hope this helps.
FollowupID: 737114
Follow Up By: Member - Andrew (WA) - Tuesday, Aug 23, 2011 at 00:30
Thanks Kanga...
FollowupID: 737115
Reply By: Member - Bucky - Tuesday, Aug 23, 2011 at 07:03
Did mine ages ago
Go this mob. And they are at the rught price too
http://www.ledautolamps.com
They have replacelent led that fit almost perfectly in my ARB bullbar
Cheers Bucky
AnswerID: 463312
Follow Up By: Kanga1 - Tuesday, Aug 23, 2011 at 11:28
Hi Bucky, that is a pretty impressive range of product they have, I just rang them about their gear and to their knowledge they have only one item they know of that causes interference ( a big truck rear light cluster) unfortunately they don't have the size I need for the cutout in my Bull Bar, bu**er. Anyhow thanks for the tip. Kanga.
FollowupID: 737140
Follow Up By: Member - Bucky - Friday, Aug 26, 2011 at 07:46
Found another, this morning
May well be listed but here goes
Click here
Cheers again
Bucky
FollowupID: 737364
