Nissan 3.olt engine fault
Submitted: Thursday, Aug 25, 2011 at 22:14
Hairy (WA)
Gday,
Is there anyone out there who can shed some light on engine analysis codes?
The code is P7-F/INJ TIMG FB.
the initial problem was loss of power and thought to be
water in fuel but have since found there is no sender unit on the bottom of the fuel filter.
any info would be appreciated
Hairy
Reply By: Notso - Thursday, Aug 25, 2011 at 22:21
Ask the guys on this
forum, I sold
mine a while back so am out of touch.
Nissan Forum
463536
Follow Up By: gragra - Friday, Aug 26, 2011 at 07:22
If you do a Google search on the fault code there is plenty of answers, mainly around the fuel pump (apparently quite expensive) and dirty fuel filters.
Good luck
737362
Reply By: Member - DAZA (QLD) - Friday, Aug 26, 2011 at 08:04
G/Day Hairy
When we had our 2008 3ltr crd patrol I would phone the Nissan State Office if I wanted any info.
When you phone ask for the Technical Section.
You get better results from the State Offices than phoning the Nissan Head Office.
We had crap fuel in our patrol and it lost power and it didn't show up on the Engine Management System.
463553
Reply By: ted - Friday, Aug 26, 2011 at 08:24
Hi Hairy
If you Google "nissan_patrol_y61_esm.zip" you will find a downloadable electronic copy of the service manual for the Y61 patrol. I have found it excellent for working on my Patrol.
463556
Reply By: Member - reggy 2 (VIC) - Friday, Aug 26, 2011 at 16:55
hi hairy there is a sensor in the air tube on the air cleaner to the body if it gets dust in it it confuses the computor try giving it a good clean out or replace it.
hope this helps cheers
463584
Reply By: TerraFirma - Friday, Aug 26, 2011 at 19:11
Could be a few things, nothing to panic about , read this link
463591
Follow Up By: deserter - Friday, Aug 26, 2011 at 21:37
Would if I could
737432
Reply By: ted - Saturday, Aug 27, 2011 at 08:16
Hairy
From the Emanual I recommended to download.
TROUBLE DIAGNOSIS FOR ‘‘F/INJ TIMG F/B’’ (DTC 21)
Injection Timing Control Valve
The injection timing control valve is built into the electronic fuel
injection pump. It controls the timer piston to change the fuel injection
timing.
The timing control valve is a solenoid valve located in the line
between high-pressure chamber and low-pressure chamber. It
changes fuel pressure in the high-pressure chamber.
When current flows through the solenoid (the solenoid turns ON),
the timing control valve opens, advancing fuel injection timing.
When current does not flow through it, the timing control valve
closes, retarding injection timing.
The ECM emits an ON-OFF duty signal. The longer the OFFduration,
the greater the advance angle. The longer the
ON-duration, the greater the retard angle. This means that changing
the ON-OFF duty ratio makes it possible to achieve an optimal
advance angle and accurately control fuel injection timing.
Ted
463621
Reply By: Hairy (WA) - Saturday, Aug 27, 2011 at 11:13
Thanks for your replies everyone.
Thats given me a few things to start looking at............
Sorry about the generic thankyou , but Im in a rush.
I dont suppose anyone has pulled the fuel tanks out of a 2000 Patrol have they? Is it a pain in the ####? Do they have a drain plug?
463629
Reply By: "Semi" Grey Nomads - Saturday, Aug 27, 2011 at 17:54
"This fault code refers to quite a few things. It is telling you there is no control over timing because there is fault that can be caused by
Harness or connectors
(Electronic control fuel injection pump circuit is open or
shorted.)
Improper fuel quality, air in fuel system or fuel restrictions"
More than likely the fuel pump..
463652
