Temporary windscreen
Submitted: Tuesday, Aug 30, 2011 at 13:54
Jon B1
I am looking for a source of clear plastic for a temporary emergency windscreen, to use in that event which I hope never happens. Any tips ?
Reply By: Doomadgee Roadhouse - Tuesday, Aug 30, 2011 at 14:32
hi Jon B1.....
I would talk to a windscreen repair man as those type of things are not needed these days, windscreens no longer "shatter" and
cave in as they used to ..... i do stand to be corrected as i know i will so go and talk to a windscreen repair man or even have a look at a wreckers and see how the car screens now crack ........
Joe
463855
Reply By: Jon B1 - Tuesday, Aug 30, 2011 at 15:26
Thanks for comment Joe,
You may be right about windscreens being smashed less often these days, but I am also interested in rear window emergency replacement, and I know they do smash. So still searching for source of suitable plastic.
463858
Follow Up By: Member Andys Aussie Adventure - Tuesday, Aug 30, 2011 at 15:38
Hi Jon B1, Try a body
shop, panel beater they have plastic that comes in a roll, Just use cloth tape to stick it on
737743
Reply By: Member - MUZBRY(Vic) - Tuesday, Aug 30, 2011 at 15:41
Gday
It would be so much easier if we new where you were..
463859
Reply By: Member - Vince B (NSW) - Tuesday, Aug 30, 2011 at 15:43
Jon.
I have used a perspex cover on the rear screen.Had it cut to size at local plastic business & use it every time I tow the van out west.
Cheers.
Vince
463860
Reply By: The Explorer - Tuesday, Aug 30, 2011 at 17:40
I drove from
Norseman to
Esperance once with no windscreen. Solution - full face motorcycle helmet...though suppose that would take up too much room for a once in a blue moon occurrence. Maybe just some M/C goggles and a face mask would do in an emergency.
My experience was way back when windscreens were not laminated. As others have suggested it would be an extreme instance in which you would damage a laminated windscreen to the point you would have to remove it totally to drive.
463880
Reply By: Member - Darryl P (SA) - Wednesday, Aug 31, 2011 at 08:28
have a look at a product called clearplex i have it on my windscreen and it works a treat if u google it u should get the info u need it may b the answer u need
463919
Reply By: Member - Alan H (QLD) - Wednesday, Aug 31, 2011 at 08:53
Polycarbonate sheeting (thin and flexible) is available at Bunnings. Cut it with good scissors. Can take a massive impact.
I put little stick on patches on the sheeting to stop it from touching the glass. Then just tape it on.
463920
Follow Up By: Member - Bill B1 (NSW) - Wednesday, Aug 31, 2011 at 09:22
Polycarbonate is the go.
Look at this link - there should be a few pics for a patrol but it is a fairly straightforward job.
I use rear window lourve clips to hold
mine on the Prado. Easy to pull the thing off for cleaning and they won't fly off like velcro.
Rear Window Protector
Bill
737808
