AnswerID: 39444 Submitted: Thursday, Dec 04, 2003 at 19:28
Member - Jack
replied:
On the back I am able to slip the jack into the square bracket that normally houses the tow bar, and can lift from there.
On the front I now have the attachment which hooks onto the bullbar (dead centre). This one is on a small length of chain, and the other part of the coupling bolts onto the jack.
Before I found this little item I would jack at the front by hooking a chain into the two towing hooks, bring it around to the front and put the jack onto that. It worked fine for me.
On the side .. I am lucky to have some custom built steel side steps, and I can either jack directly onto these or use the front chain attachment. Have not had to do a side lift as yet, but tried it out just in case.
So far (touch wood) it has not fallen off the jack at any point .. although at times it has looked precarious.
JackNo trees were harmed in the making or sending of this message.
However a great number of electrons were terribly inconvenienced.
Reply 4 of 5
FollowupID: 257228 Submitted:
Friday, Dec 05, 2003 at 20:05
Member - Jack posted:
Hi Troopie:
The thing(gizmo) is called a Hi Lift Bumper Lift. If you have an ARB catalogue it is under the recovery section (Page 53 in my copy).
If you let me have an email I can scan and send you a copy of the part if you don't have the catalogue.
The earlier option I discussed was using recovery chain, hooked up to the two front recovery points on my 80 series, brought around the front and I used to just put the jack in the middle and lift it from there. Then I found the ARB thing.
Jack (good name for this thread....).No trees were harmed in the making or sending of this message.
FollowUp 2 of 3
