Mitsubishi Challenger
Submitted: Friday, Dec 05, 2003 at 09:01
ThreadID: 8978 Views:1795 Replies:3 FollowUps:0
Recently bought a 2000 model challenger, at 100km/hr there is a vibration up through the steering wheel. The service manager at the dealership where I bought the car has done a wheel balance that hasn't corrected the problem. I asked for a wheel alignment but was told that probably would not fix the problem.
Reply By: Well 55 - Friday, Dec 05, 2003 at 09:26
Go for an alignment and 'on car' ballance.
The alignment to make sure the wheels are pointing in the same direction, and on car ballance will duplicate on road driving.
AnswerID: 39499
Reply By: ron1 - Friday, Dec 05, 2003 at 11:32
also check ur tail shaft , and ware in any steering joints
ron
AnswerID: 39506
Reply By: Eric Experience. - Friday, Dec 05, 2003 at 22:25
Paul.
The most likely cause is a delaminated tyre, swap the front to back or jack up the front wheel under the wishbone so that the tyre is 1 mm of the ground then spin the wheel by hand if the tyre is delaminating the tyre will touch the ground at the problem spot. Eric.
AnswerID: 39544
