scrub bars
Submitted: Friday, Dec 05, 2003 at 23:30
Stuart
hi all, l want to fit some scrub bars to my 80 series cruiser, l priced the ARB ones and thet are a lot of kanga for two bent poles, does anyone know of cheaper versions or am l better off going to a steel fabricator and getting some made up
Reply By: Hilly - Saturday, Dec 06, 2003 at 00:22
K&N in Canning Vale WA put the ones on my 80 series and I think it was about $280 a couple of years ago.
Hilly
39551
Follow Up By: Stuart - Saturday, Dec 06, 2003 at 09:08
A lot cheaper than ARB, but l am in Vic so l will keep looking!
257241
Reply By: Member - DOZER- Saturday, Dec 06, 2003 at 16:42
Gday
Had some ARB, but the frames to the chassis hang down low enough to pick up pieces of wood you run over - pushed up a sill on my last 80. This one has sliders welded to the chassis and then bolted at flanges, strong enough to jack off of.
Might be able to get a set made with bars forward.
Andrewwheredayathinkwer mike?
39563
Follow Up By: Stuart - Sunday, Dec 07, 2003 at 17:28
Are they home made or did you buy them, and if you bought them where did you get them and for how much? If you made them would it be possible if you sent me some pictures of them or a drawing?
thanks......Stuart
257285
Reply By: Willem - Sunday, Dec 07, 2003 at 08:38
Hire a pipe bender, buy all the pipes and angles and if you do not have a friend with a welder take your made pieces to a steel fabricator. Shouldn't cost too much to tack together.
Cheers,Willem
Always going somewhere
39601
Reply By: Truckster (Vic) - Monday, Dec 08, 2003 at 09:33
www.lcool.org, check the forsale/trader section..
39646
