FollowupID: 744629 Submitted:
Wednesday, Nov 16, 2011 at 14:56
member - mazcan posted:
hi sangster
no i'm not mixed up
my thread was for you
i'm suggesting that you check your gas struts
as the reason you have to ask your wife to help lift the poptop is:::
i believe the pressure in your gas struts is failing and probably need replacing
i then recommended you do this before spending unneccessary money on additional props that marg talked about
note : i have never drunk whiskey in my life
as to me even the smell of it tells me one could run their car on it or use it to clean the injectors on a diesel engine lol
cheers barry
| "QUEBBAMBIDDYBUMTAL" attempt to achieve the impossible immediately and a miracle a little later |
