Crown Wheel & Pinion prices
Submitted: Tuesday, Dec 09, 2003 at 15:27
ThreadID: 9052 Views:2186 Replies:1 FollowUps:4
Looking for the people with the best prices on crown wheel and pinions for LN106 hilux. Anyone with a good supplier let her rip.
Reply By: Member - DOZER- Tuesday, Dec 09, 2003 at 16:38
Ive got an old Hilux L.S.D diesel (4.3) diff in the shed.
Andrewwheredayathinkwer mike?
AnswerID: 39748
Follow Up By: howesy - Tuesday, Dec 09, 2003 at 18:57
Where are you at. Already spent 480 on it putting new bearings in and wasn't amused to find it was just as noisy as when i put it in to be fixed.
FollowupID: 257417
Follow Up By: Truckster (Vic) - Tuesday, Dec 09, 2003 at 22:48
He is around Wollongong...
FollowupID: 257437
Follow Up By: Member - DOZER- Wednesday, Dec 10, 2003 at 08:35
Gday
Yes Wollongong, if your gears are worn too much a certain way, they wont run quiet at all. If you pull it back out, a bit of bearing blue on the teeth will see where the contact patch is (if it has been set up wrong) or whether the gears are worn abnormally.
Andrew. wheredayathinkwer mike?
FollowupID: 257459
Follow Up By: howesy - Wednesday, Dec 10, 2003 at 23:12
He blued the gears and said that the wear was minimal and I would get away with it. He admits that perhaps he was over optimistic and has offered to fit a crown and pinion with no charge for labour. All I need to do is track down either a bargain new one or decent second hand
FollowupID: 257548
