L300 replacing balljoints and wheel bearings
Submitted: Wednesday, Dec 10, 2003 at 14:44
L3004wdVirgin
I own a 84 l300 4wd and need to cahnge the left and right, upper and lower ball joints as
well as the front wheel bearings. It is going to cost me more then I can afford at the moment to get someone to do this. The labour alone is going to cost around $300. Part are around $350. Could someone point me to a website that shows you how to do this or is someone able to talk me through it.
Reply By: ron1 - Wednesday, Dec 10, 2003 at 20:42
buy a manual for it should have all the info you need to change, and if your a little mechanical minded then you should get it done easy, and upper and lower ball joint?? on a 4x4 ? you sure its a 4x4 as the front
wheels should be on a hub??, i could be wrong
39885
Follow Up By: ron1 - Wednesday, Dec 10, 2003 at 20:49
mind you i've only had a hi-lux and land cruiser, :) and never seen one come in to the work
shop either,
learn some thing new every day ay lol 'cheers
257527
Reply By: Eric Experience. - Wednesday, Dec 10, 2003 at 22:36
L300.
There is a variaty of
tools to remove ball jionts, some rough mechanics use a piar of hamers. I find the best tool is like a very sturdy G clamp with a falked section that slips under the rubber boot, go to a decent tool
shop and have a look. Eric.
39902
Reply By: Eric Experience. - Wednesday, Dec 10, 2003 at 22:38
L300.
39903
