Idle speed
Submitted: Saturday, Dec 13, 2003 at 17:20
Member - Terry
Hi my first corrospondance
Can any one help
Vehicle Toyota turbo RV 79 series trayback
Has anyone worked out how beat the computor and reduce the idle speed when the air conditioner is switched on. Our vehicle runs at 1000 rpm and toyota says it cant be adjusted.
Has anyone experience with full air-bag conversion. Is it a propersition to fit all-round or front only. Currently I have fitted Polly airbag helpers to the rear which helped to stand it up under full load
Many thanks
T.C.
Reply By: Truckster (Vic) - Saturday, Dec 13, 2003 at 22:01
The revs on my car drop when air cond is on and it SUCKS.... the thing shakes it idles that low...
Leave it where it is!
40152
Follow Up By: Hughesy - Monday, Dec 15, 2003 at 06:28
That's because the nissan motor can't handle the load.....whereas the toyota motor....
Left ya self wide open Truckster...
Hughesy
257824
Follow Up By: Well 55 - Monday, Dec 15, 2003 at 08:20
My GU 4.2 runs at 1000 revs with A/C on, so Truckster yours should have a idle up adjustment somewhere.
257828
Follow Up By: Truckster (Vic) - Monday, Dec 15, 2003 at 11:42
Actually its only a setting on the pump, but just a slut to do..
Would you like to talk about Toyotas reliable 1HD-T Main Bearings?
257852
Reply By: bill - Sunday, Dec 14, 2003 at 20:28
Why worry about it..once you start messing with electronics ..you'll be sorry.
Have you put something on the back of your beast yet????
40192
Follow Up By: Member - Terry- Monday, Dec 15, 2003 at 20:02
Thanks for your comments
The thing revs that fast that you need to change to second to keep under 40ks going through town - would be good to back it off a bit
Yep when we are loaded in travel mode with boat and all, the truck weighs 2.5 + tons + the van - all up around 4 tons
Why worry about the mains when the overdrive shaftwill probably go first
T C
257893
