Dual batteries series 100 TD cruiser
Submitted: Monday, Dec 15, 2003 at 19:01
Evvo
After advice about dual batteries for TD 100 landcruiser. ARB dual battery setup comes with a 55 amp hour battery only (GNB ED4). ARB tells me there is no room for a larger capacity battery. I dont think this will run the engel and camplight for much more than a day. What alternatives are there without spending megabucks?
Reply By: Brad - Monday, Dec 15, 2003 at 21:16
I had an ARB dual battery put in my LC100 V8 in May and it has an 80 amp hour battery. Its not the TD obviously, but I thought there was as much room under the bonnet as the V8.
Regards,
Brad
40297
Follow Up By: Jayson - Monday, Dec 15, 2003 at 21:46
Evvo,
You haven't said whether you have three batteries in your dual system or have split the original two. I split the dual "parallel" battereries up in my new TD100 and used the surepower smart solenoid I kept from my old '98 100 series. It worked fine in the old one and works great in the new one too. The 1hd-fte starts fine from one battery as it has no glow plugs and a lower compression ratio that the 1hz. It does have an intake air heater for really cold starts. I did all my dual battery stuff using the original vehicle harness and only had to solder a wire into the harness for a voltage to trigger the smart solenoid when key is in the start position. I have two 700cca Yuasa Overlanders and have used these for about the last six years, get about three years out of them.
Jayson,
Karratha
257916
Reply By: Evvo - Tuesday, Dec 16, 2003 at 13:25
Jason, ARB unit is actually a 3rd battery. Both ARB and toyota dealer told me that toyota would not cover warranty if the original dual battery was split. I understand the problem is lack of space on the rear off drivers side of the engine bay for a larger battey.
Evvo
40370
Follow Up By: Barry (Vic) - Wednesday, Dec 17, 2003 at 23:04
I have a Piranha setup in my LC100TD. They left the original two batteries untouched and added the third on the passenger side. This involved moving a few Toyota bits (including the fuel filter) but the whole job was done very professionally.
The added battery in my case is an Exide Deep Cycle 65Ah.
Barry
258095
