looking at a 100 series
Submitted: Monday, Dec 15, 2003 at 20:27
thomo
Looking at a 100 series tommorow ive allready had a look at it once just wondering if it sounds allright its a 98 model standard
barn door job with a 1hz done 160000klm nothing bashed underneath only the rear shocks so its spent a lot of time on dirt roads was owned by electric hydro in tassie interior has a few marks and a couple of drill holes were things were bolted down,any 100 series owners out there no what i should look out for. thanks
Reply By: Mark from Getaway Portable Refrigerator Hire - Monday, Dec 15, 2003 at 20:33
Thomo, Price?
40280
Reply By: thomo - Monday, Dec 15, 2003 at 21:17
Got $32000 on it should be able to get it for $30000
40298
Follow Up By: Tassie Dave - Monday, Dec 15, 2003 at 21:25
I paid $35000 last week for 01 std with 58000km from the Uni of Tasmania. Hydro Tasmania vehicels are generally kept in good condition, mainly used for general 4wding. Not like the mainland power station's or
mine's. I've worked at them in NSW and find that vehicles in tassie are better.
257910
Follow Up By: thomo - Monday, Dec 15, 2003 at 21:41
I wouldnt mind one like yours but $30000 is my limit was going to get a 80 series but all the ones i could find were either petrol or had to many klms.I work at a power station in vic and i defenitely would not buy one of there old ones the coal stuffs everything, so you think the tassie hydro ones would be okay.
257914
Reply By: bernie1 - Monday, Dec 15, 2003 at 21:29
thomo,
1. look for rust spots across the top of windscreen under the rubber seal,peel rubber back with knife blade
2. some 100 series have clutch shudder
3. look for excessive grease on the front swivel joints, could mean seals have gone
40300
Follow Up By: thomo - Monday, Dec 15, 2003 at 21:34
This ones clutch does shudder a bit ,why did the 100 series suffer from this.
257912
Follow Up By: bernie1 - Monday, Dec 15, 2003 at 21:44
don't know, apparently toyota still don't know why, after market people may have to find remedy to fix it.
257915
Follow Up By: thomo - Monday, Dec 15, 2003 at 21:52
Ive got a 75 series as
well and it shudders a little bit every now and then but the 100 is a lot worse compared.
257918
Follow Up By: GaryInOz (Vic) - Tuesday, Dec 16, 2003 at 09:26
Early ones: If IFS, front diff self destructs. 5 stud
wheels, LOOK at the condition of the studs, known to part company at the most inopportune time (halfway around a corner...)
257950
Reply By: bernie1 - Monday, Dec 15, 2003 at 22:01
if the one you are looking at is worse than the 75 series give it a miss, my 00 100 series std diesel(77000 km) has minor shudder when cold, no problem once it warms up for some reason.
40305
Follow Up By: thomo - Monday, Dec 15, 2003 at 22:09
When i took it for a drive it was cold and it did shudder i drove up the highway by this time it had fully warmed up the missus drove the car back to the dealer and it didnt shudder for her so it was either the way i was driving it or it might be the same as yours anyway its going to a diesel mechanic friend of
mine tommorow so he can go over it
257924
Reply By: Tassie Dave - Tuesday, Dec 16, 2003 at 20:31
Thomo
Did you buy it??
40420
Reply By: thomo - Tuesday, Dec 16, 2003 at 21:40
Yes dave i did buy it ,I took it to a friend of
mine who owns his own diesel mechanic business he had a look at it from one end to the other took about three hours all he could find was a slight leak from the power steering pump he said it was a common thing with landcruisers take about an hour to fix,We did a compresion check and all cylinders were 540psi, brand new there 550 so it in preety good nick, oil in motor ,box trans case and both diffs was clean and no metal and nice and clean underneath no dints or scrapes so hopefully it will be a good buy.
40426
Follow Up By: Steve - Tuesday, Dec 16, 2003 at 22:33
And the final price ?
258012
Follow Up By: thomo - Wednesday, Dec 17, 2003 at 06:25
They wanted $32000 plus on road cost i got it for $32000 with a few things fixed on the road.
258027
