Chescold 12v wireing (lost the lead)
Submitted: Thursday, Dec 18, 2003 at 08:02
fatz
A mate has lost the 12 volt lead for his old Chescold 3 way. It has an aftermarket connection on the back of it which was on before he got it. We think it's an F40 model. There are two wires leading to the connection, one Blue and one White. Can anyone tell us which is positive and which is negative or does it matter as neither seem to go to ground. I presume they attach to an element of some sort.
Reply By: Well 55 - Thursday, Dec 18, 2003 at 08:11
One would be power the other earth return, stick a meter both ways to check for a circut. My guess would be blue for power.
If the 240 cable is connected check that.
40518
Reply By: Dave from Fraser Coast 4WD Club - Thursday, Dec 18, 2003 at 08:24
How will the 240 cable help, AC is very different to DC?
I don't have
mine at home at the moment, as suggested abouve try with a multimeter. If I had to guess, I would also say blue.
If all else fails go into your local
camping store (or maybe ring chescold) and find out.
40519
Follow Up By: Well 55 - Thursday, Dec 18, 2003 at 09:51
Maybe 240 goes to the same ellement.
258112
Follow Up By: Bonz (Vic) - Thursday, Dec 18, 2003 at 17:22
Blue is an international colour for neutral, that would be earth in a 12 v situation.Laterally Literal
Seriously Cerebral
303142
Follow Up By: Dave from Fraser Coast 4WD Club - Thursday, Dec 18, 2003 at 17:28
well there you go!
303144
Follow Up By: Well 55 - Friday, Dec 19, 2003 at 07:31
Well I never.
303178
Reply By: Penguin - Thursday, Dec 18, 2003 at 08:44
All the 12 volt connection is supplying is a heater element, so I'm not convinced that polarity matters.
40520
Reply By: Member - Ross - Thursday, Dec 18, 2003 at 09:03
Just had a look at a newer one and both wires are the same. I tend to agree with
Penguin that it doesn't matter as the heater element is only a resistance.
Why not try an email to Chescold/Electrolux to be sure.Fidei defensor
Rosco
40524
Reply By: chrisfrd - Thursday, Dec 18, 2003 at 15:59
NO!!!
Don't just whack it together! Two reasons...
1. For 12V, the cabinet could be connected to the ground-side of the element. This would make sense for safety reasons as it would also be tied to the earth for the 240V side (which I think they are). If you get the + on the grounded case, it won't matter until you sit the fridge in a vehicle, in which case you will short the battery and such... on the 240V side, there are more dangers;
2. If this loop occurs, the neutral side of the 240V supply could make it's way to the chassis of the vehicle. If the 240V supply socket or anything else connected behind that supply is faulty, you could be fatally injured by being the earthing rod out of the vehicle.
Do it properly, if there is any doubt, then there is no doubt - Get it fixed or get creditable information to do it yourself.
40551
Reply By: rodeoowner - Thursday, Dec 25, 2003 at 22:48
Sheesh! I repair these fridges. Polarity on 12V doesn't matter. It is hooked up to a aheating element (resistor), so it doesn't matter. The cabinet isn't earthed on 12V. The wires run directly to the element.
41096
