best laptop for GPS etc
Submitted: Thursday, Dec 18, 2003 at 22:37
ThreadID: 9225 Views:3291 Replies:9 FollowUps:21
I'm looking into acquiring a new notebook computer to run OziExplorer etc., as well as being competent for lots of digital photos along the way on my trips.
So far I've narrowed the field down to Dell or Compaq. Having been caught with Gateway a couple of years ago, as well as crappy service for the severa times it had to go for repairs, I'm a bit wary of the similar appearing setup with Dell (ie mail order, everything done by phone)
Can anyone offer their experiences with either of these brands.
My apologies if this is a little off list
Reply By: Member - Bob - Thursday, Dec 18, 2003 at 23:04
Bob,
Oziexploirer will run quite well on a 333MHz processor. When you say competent for digital photos are you Photoshopping them or just storing them? If you are just storing then again you don't need a new laptop, just a moderately sized hard drive and USB. You could probably survive perfectly well with a 2-3 yo Toshiba, but thats probably not what you wanted to hear :-). Of course the advantage of the slightly older machine is that it will have a serial port for the GPS - no need to buy a serial/USB adapter.Bob
AnswerID: 40595
Reply By: Hendo - Thursday, Dec 18, 2003 at 23:23
Bob - I have used an older Dell laptop with 333Mhz Celeron. It runs windows XP quite happily, and I only use it for Maps, and to store digital photos on until I get back home.
I keep some of the maps on CD, and some on the hard drive - I'll load the relevant maps on the Hard Drive before a trip, and as pointed out above, it still has a serial port for the GPS to upload waypoints, and download the track at the end of each day.
Low cost, and fast enough, and so far (touch wood) reliable.
I don't have it as a moving map display - haven't worked out how to get the cook into the back seat (while we're travelling, of course), or alternatively get her to nurse the laptop while sitting in the front seat!!
Hendo
AnswerID: 40598
Reply By: KG - Friday, Dec 19, 2003 at 00:47
i use the DELL C or D series at work and have had no issues with them. they seem to stand up ok. i doubt you would have any problems with them going bust or running off with your cash, etc. the only downside to dell is the 2week delivery time to au.
for pure toughness you can't go past the IBM notebooks... i've seen them bounced around on the floor of a ute for years on end and they still keep going. probably about 20-30% more than a dell.
one thing to avoid like the plague is toshiba... not only do they break a lot, but when they do break the warranty is pathetic (toshiba outsource the warranty work)
cheers,
KG
AnswerID: 40611
Reply By: Jarrod - Friday, Dec 19, 2003 at 01:10
Bob,
I spent the last two months trying to make the exact same decision you are now contemplating.
I've ended up with a Hp/compac(same thing) model Nx9000. without going into all the details of the machine, its basically a 2.0 Ghz mobile processor, 40 gig Hard drive, 15 inch active tft screen, 512 meg ram, cd combo ( reads writes cd,s plays dvds.) has two pcmcia ports, 3 usb plus all other usuals ( s video, audio etc)
Ok, why the compac, - 1. value for money, - over all cheaper (between these two brands, and also toshiba.) more megs, gigs and Hz for your buck.
2. 12 month Australia wide warranty - I know warranty can be a bit of a touchy subject at the best of times, but HP seemed the best to me.
3. solid steel chassis construction. Dell's screen is attached with large plastic hinges !
4. Serial port - hp nx9000 - standard with 9 pin d type com port. ( check any model you propose to buy.)
5. Mobile processor - Battery life about 4 to 5 hours
6. touchy pad mouse thingy..!!! i liked Compaq's touch pad with side scroll bar better!
7. resale value. - lets face it, the second hand price of these thing falls faster than used beer, but hp compaq seems to hold up beter than dell.
8. I was happy with the 40 gig HD as i have loaded all natmap raster maps on HD still have truckloads of blank space.
9. the HP compaq tft screen is a better quality manufactered unit than the dell ( according to a forum somewhere else!! - take this one with a grain of salt, I did !!)
I currently run a magellan trailblazer xl, straight into the pc comport with ozi ex, ran moving map mode from melb. to horsham and back logged a track file the whole way, worked and absolute treat. Couldn't be happier with it...
hope this helps your research,
Jarrod.
AnswerID: 40612
Reply By: Member - Wim (Bris) - Friday, Dec 19, 2003 at 08:39
Bob.
All the techs at our work run Dell Latitudes as do I. We purchase 3 year "comprehensive" warranty on top of the normal warranty. Our laptops are out on site all the time in airconditioning plantrooms and on building sites. We have tried a lot of laptops over the years and the Dells have the best record and by far the best service backup.
July/Aug this year we travel 7000k's with 4,500 of that on dirt. No problems at all with may laptop (Dell D800).
If you require a serial port check the laptop you intend to buy as many today do not have serial anymore.
RegardsThis 4WD stuff is addictive,
time consuming & expensive.
AnswerID: 40621
Reply By: Groove - Friday, Dec 19, 2003 at 08:47
I have had experience with Dell, Compaq and Toshiba laptops (im in IT industry). The Dell are OK but I have seen a number of physical failures on them, eg cracks where the screen is hinged and attaches to the base.
The Compaq and Toshiba seem to cause very few problem. I personally use a toshiba laptop (satellite pro about 4 years old now). It has been used with Oziexplorer since new. Simpson, Cape York, Gibb River, Fraser etc etc without any problem at all. It is a very tough unit, all sorts of temperatures and knocking about without a hitch.
It now lives under the drivers seat of my GU patrol connected to a 7.2 inch touch screen mounted on my center console. My parter did not like having to unpack the lap top and sit it on her lap whenever I wanted to add look use Ozi so enter the touch screen.
Pics can be seen on
my web site
The site is very rough at this stage and takes a while to load. It will be improved in the near future.
AnswerID: 40622
Follow Up By: cokeaddict - Friday, Dec 19, 2003 at 08:59
Hey Groove,
I'm Impressed mate. Looks great to me. Where did you find the kit for the battery monitor?I love it when you talk DIRTY !
FollowupID: 303183
Follow Up By: Groove - Friday, Dec 19, 2003 at 09:25
Its a jaycar kit that cost about $14, actually its two of the same kits squeezed into one case. The original kit comes with 10 individual LEDs but I used the one piece LED bar graph display because it looks a bit better, this is also a Jaycar item worth about $4.
The hard part was cutting the slot for the LEDs in the case, I used a Dremel for this.
The artwork is inkjet printing on a 3M self adhesive product.
FollowupID: 303184
Follow Up By: Matt (W.A.) - Friday, Dec 19, 2003 at 10:06
Groove
where did you get the funky touch screen and how hard was it to install? approx cost...ect. Is it just an extention from the laptop? any info would be great?
Thanks in AdvanceKeep It On The Rough Stuff
Matt (W.A.)
FollowupID: 303193
Follow Up By: Groove - Friday, Dec 19, 2003 at 10:30
Hi Matt
I got the touch screen from ebay (www.ebay.com just do a search for lilliput). The guy selling them is based in Hong Kong. It comes with or without touch screen option and cost about $400 delivered with touchscreen.
It arrived in three days from the time I placed my order. A friend of mine decided he wanted one after he saw mine and his also arrived in three days.
It was very easy to mount, the bracket supporting it actually sits in where the ashtray used to be. The bracket is very versatile.
To use with the laptop all I did was plug it in to the external monitor port on my laptop and it fired up staight away at 800 * 600 resolution. The touch screen option plugged into the USB port on the laptop, I installed the drivers that came with it and also worked first go.
The touch screen is very effective. Some of the buttons in OziExplorer are too small to use your fingers but the screen cames with a stylus and it works great. Using fingers really makes the screen grubby anyway.
I found a freeby touchscreen keyboard program on the net that pops up a keyboard on the screen for when you want to enter text. A keyboard appears on the screen and you simply touch the relavent keys, this is useful for name searches, naming waypoints etc.
The screen is very bright even on sunny days.
I will document this stuff in more detail on the web site.
FollowupID: 303196
Follow Up By: Matt (W.A.) - Friday, Dec 19, 2003 at 11:20
Groove,
Sounds Great I will investigate further. i have an idea to mount it into the front of the glovebox for the same effect or on the mount so that i can see it whilst driving.
Matt (W.A.)
FollowupID: 303200
Follow Up By: Member - Peter (WA) - Saturday, Dec 20, 2003 at 15:02
Groove thanks for sharing the info ,I also will be looking at this in greater detail This is not my car anymore
Peter York 4x4
FollowupID: 303303
Follow Up By: red rover - Sunday, Dec 21, 2003 at 19:43
I guess this may be a stupid question but as an IT professional you would be the one to ask.
How do you get your laptop to run with the lid closed? Mine goes to sleep when you close the lid.
John Fenn
FollowupID: 303346
Follow Up By: Groove - Sunday, Dec 21, 2003 at 22:27
Hi John,
The laptop in question a is a toshiba satellite pro, I have two of these about three years apart, both models have an option in the hardware setup that give you the choice of what to do when the lid is closed, either hybernate the machine or the option that I have chosen , do nothing and keep working.
I am not sure what other brands offer this option, in fact I didnt really know that mine did untill I went looking for it.
This type of option would be in the hardware or BIOS setup of your laptop if anywhere. With some computers you see a message displayed birefly when the thay start up, eg press DEL to enter setup mode, this is is the BIOS setup area and allows all sorts of configuration options to be set. With the toshiba laptops I have used over the years the hardware setup is a program that is run from control panel. This program is usually installed by default but if it not there the appropriate version for your OS and machine is available from the toshiba web site.
Some laptops on the other hand simply do not shut down if the lid is closed if they detect a monitor connected to the external monitor port. You can test this by plugging in a normal desktop monitor to your laptop, when you see an image on both screens shut the lid and see what happens. Sometimes you have to press a combination of keys on the keyboard to direct output to the external monitor. If it works with a normal monitor it will work with the type of screen I have used.
If this option does not exist it would not be too hard to diable the small switch that is tripped when the lid is closed.
Hope this helps.
By the way in answer to the original message I was at a computer market today in North Rocks in Sydney that had a large number of second hand laptops all very suitable for this application. All brands and models. Pentium III processors up to 1ghz all under $1000.
FollowupID: 303357
Follow Up By: theratt - Monday, Dec 22, 2003 at 13:03
groove , my screen is on the way, just what i was looking for
can you remember what web site you downloaded the
on screen keyboard?
FollowupID: 303378
Follow Up By: Matt (W.A.) - Monday, Dec 22, 2003 at 13:12
Ratt,
There is an on-screen keyboard in Windows XP in Programmes-Accessories- Accessibility-On-screen Keyboard, it just depends on what operating System you are running.
HTH
Matt (W.A.)
FollowupID: 303379
Follow Up By: Mad Dog Morgan (Vic) - Monday, Dec 22, 2003 at 15:28
>How do you get your laptop to run with the lid closed? Mine goes to >sleep when you close the lid.
I manage this from xp:
Right click the desktop
click Properties
screensaver/power/advanced
there is an option about what to do when I close the lid of my portable computer:
Do Nothing
Standby
Hibernate
I may be mad but I'm not crazy
Hooroo
Ray
FollowupID: 303384
Follow Up By: Member - Peter (York) - Monday, Dec 22, 2003 at 15:39
Groove
Peter York 4x4
FollowupID: 303385
Follow Up By: Member - Peter (York) - Monday, Dec 22, 2003 at 15:44
Groove , please help I have never used ebay and have no idea how it works , I have been looking for the supplier of the screen you have in your Patrol ,is there an eisier way to contact the supplier as there seems to be several differant adds thanks for any help ( key board challanged driver)This is not my car anymore
Peter York 4x4
FollowupID: 303386
Follow Up By: red rover - Monday, Dec 22, 2003 at 16:03
Yes well that's fine except I am running an older Mac and you cannot do it because the cooling intake is through the keyboard. So I shall just make a little bracket that keeps the lid about 1cm open.
Thanks for the help guys.
I may have just found the one reason that I would buy a PC.
NAH!
John Fenn
FollowupID: 303388
Follow Up By: Groove - Tuesday, Dec 23, 2003 at 15:19
Hi Therat,
As Matt said there is an oncrseen keyboard that is standard with XP. I use win98 on this laptop, it works fine and I never got around to changing it. The keyboard I use is called click-n-type. I downloaded it from www.download.com. Go to this site and do a search on "onscreen keyboard" there are quite a few but this one is the free, most of the others are trial version that you can try for time period but then have to buy.
Hi Peter,
I found this guys add on eBay a bit confusing as well so it’s not just you.
Basically you buy the goods by clicking on the "BUY IT NOW" link on the eBay site. The supplier sends you an email to say thanks now I will send you the goods when I receive payment. Then you use a third party internet payment service to send the supplier the funds and the supplier sends you the goods.
This is the link to the item on eBay
7 inch touch Screen
I used the Pay Pal site for payment, when I received the email form the supplier there was a link to this site in the email. The supplier will also accept other forms of payment such as money order etc. The paypal site is reputable and takes credit card payments. When paypal send the payment to the supplier the supplier send you the goods
The suppliers email if you wish to contact them directly is Extreme_audio@shaw.ca
Hi John
About the fact that you use a Mac, well nobodys perfect!
FollowupID: 303514
Reply By: Member - Timothy - Friday, Dec 19, 2003 at 15:02
Wow Groove
great set up
you've got a lot of people thinking hmmm
timothyDefender Extreme
AnswerID: 40651
Reply By: bob_h (Brisbane) - Friday, Dec 19, 2003 at 20:10
Thanks everyone... now I'm thinking!
Groove... very impressive dash setup- do you recall the cat#s for the Jaycar bits and pieces?
Bob_h
AnswerID: 40681
Follow Up By: Groove - Friday, Dec 19, 2003 at 22:23
Hi Bob
Car Battery monitor kit cat KA-1683 $16.95 (rated simple by Jaycar)
Led Bar Graphs Cat ZD-1702 $4.50
Thanks for the compliments guys I guess I really am a nerd at heart. I have found that I tend to use Oziexplorer much more since I installed the touch screen. I have it set up so that when the PC starts up it loads Oziexplorer automatically and starts moving map display automatically, so basically I press one button and a short while later up comes my position.
The only thing I havnt figured out is how to set a default zoom level so that when Ozi starts up and the map is displayed it will automatically display at 150% zoom. Any Ideas anyone?
FollowupID: 303242
Follow Up By: Jarrod - Friday, Dec 19, 2003 at 23:34
Groove, Re Ozi, you could try in config, go to system, then in the " at start up " box, tick " Set last zoom and position ?? problem is of couse if you close on a different setting...
Jarrod.
FollowupID: 303251
Follow Up By: Groove - Saturday, Dec 20, 2003 at 10:08
Thanks Jarrod I tried this a couple of times and it doesnt seem to work, I will keep playing.
FollowupID: 303271
Reply By: Member - JohnR - Friday, Dec 19, 2003 at 22:51
Groove is showing an interesting way and I guess will not be getting his truck through river crossings with so much electrical trickery low down in it and under water like some we have seen here.
If any like the thought of buying reasonably well for laptops and the like you could look at Grays Auctionswhere I have bought a bit of stuff over time, including my current laptop. Read the provisions though. I have found them good to deal with. Monitors too, as well as desktops. They have a Dell auction every two weeks.
AnswerID: 40691
Follow Up By: Groove - Saturday, Dec 20, 2003 at 10:16
Thought about the water crossing issue John and have taken a few precautions.
I have wired a circuit breaker into the wiring that feeds power to this gear and I cut power to the area. Also I have left enough length in the cables so that I can lift the whole thing onto the rear seat, this is also handy if I need access to the laptop for whatever reason. I figure if I'm in that deep I will have a lot more to worry about than a wet laptop.
I can also vouch for grays, they have a lot of good gear at reasonable prices and a laptop for use with mapping and Oziexplorer does not have to be the latest and greatest.
FollowupID: 303275
Follow Up By: Member - JohnR - Saturday, Dec 20, 2003 at 10:35
Groove, thought the best precaution may be to have the inverter and the motherboard up under the roof in a pod actually and hang the monitor from the top by the mirror mount or replace it. That 7" one I think inverts.
I would like to protect me in the car and the electricals, as one does hear of trucks getting stuck in water crossings.
FollowupID: 303277
Follow Up By: Groove - Saturday, Dec 20, 2003 at 15:45
I did think about a roof pod but ruled it. The screen is simply a bit too bright (especially at night) and I thought it might be a bit distracting up high. However if anyone is interested in this approach the bracket supplied with the screen will allow it to be mounted above or you can run drivers to invert the image that comes form the computer.
I dont run an inverter I actually use a dedicated 12v laptop power supply (targus) so there is no risk of 240V electrocution, but a very good point to keep in mind if running an inverter.
FollowupID: 303305
