Saturday, Mar 24, 2012 at 18:07
Lets clear up a few false notions.
A
battery is not a bucket, it is a chemical system, and the notion of "FULLY CHARGED" in my opinion is a contrived one.
There are approximate voltage figures that indicate "state of charge".
These figures are only valid with the
battery at a resting state, not being charged, not being discharged and having been that way for some time.
These figuers are temperature dependent and there are slight variations dependent on
battery chemistry.
While more or less reliable thay are far from absolute.
There is no fixed and relaible measure of
battery capacity and state of charge is likewise a fluid concept.
People want to think their
battery is like a bucket and there are plenty out there that will sell to that desire.
Moving on.
To charge a
battery we have to apply a voltage higher than its resting terminal voltage otherwise no current will flow and no charging will occur.....
We charge a
battery with a higher volatge than its resting voltage..after we remove that charging voltage the
battery will take some time to settle back to a resting state.
Now this is where some will argue about what is "Fully Charged"...if we charge a nomonal
battery with a nominal voltage like 13.8 volts once universally considered the optimum long term charging voltage.
The
battery will reach a state of "charge equalibrium" where the
battery is accepting no more charge and any current flowing is wasted or lost ( no drama).
Your conventional nominal
battery will not excessivly gass nor loose excessive water.
This
battery would have once been considered "FULLY CHARGED" and would settle back to 12.5 ish volts, and if it is healthy it will hold that for weeks or months if left alone.
There have been some changes in
battery chemistry and some changes in what people are saying.
many would now claim that that
battery was not fully charged and recomend charging at a higher voltage to get that
battery "FULLY CHARGED"
Now the terminal voltage may settle to 12.8 volts ( or whatever) after this....but in the long term over a couple of hours or so ( even a day) the
battery will still settle to arround 12.5 volts and stay there if healty and left alone.
In my opinion it has been over charged, not in a problematic way, but over charged all the same, because it will settle over time.
NOW
with the addition of calcium to batteries and changes in acid chemistry, some of the charging voltages have changed..and lots of things are misunderstood.
Especially sulphation.
One of the chief causes of sulphation is overcharging.
I do not believe for a minute that charging your
battery at a higher voltage each day will reduce sulphation....the opposite actually
Keeping your
battery cool will reduce sulphation
Not allowing your
battery to remain under charged will reduce sulphation.
Minimising deep cycling will reduce sulphation.
Charging your
battery at the optimum and expedient rate will reduce sulphation.
Using a charger withn a pulsed antisulphation program will reduce sulphation
Not regularly over charging your
battery will reduce sulphation.
As for various batteries being regularly charged with higher voltages reducing their life......damn tootin' it will.......but don't get bent out of shape over it...elivated underbonnet temperatures probably do more damage to car batteries.....especially AGM and other sealed batteries.
13.8 volts will still fully charge any of the lead acid
battery family, but it may take some time.
The only time it is necessary to charge a
battery at the higher voltages is to overcome charge resistance that some batteries can develop or to speed the charging rate.
If you have a good quality modern charger or regulator it should do all this for you.
Don't get bent all out of shape over all this, you could worry all you want about ya batteries an not add a single hour to their short lives.
As for what is optimum for an individual
battery......there is a great variation in small things with what is being done with batteries....consult the manufactures specifications for that model of
battery.
481281
