Defense pak
Submitted: Monday, Dec 22, 2003 at 10:56
jme
has any one had to reprogram their defense pak immoboliser after a flat battery?
if so can someone help with the code?
Reply By: Truckster (Vic) - Monday, Dec 22, 2003 at 12:00
Could you narrow it down to planet, then country, then state, then maybe car model and year? ;)
I hear Saddam has the code...
40838
40839
Reply By: Xtra - Monday, Dec 22, 2003 at 18:33
Do you have a model number ,if not can you describe the remote and the state you purchased it ?
Dan
Broome Car Security
40870
Follow Up By: jme - Wednesday, Dec 24, 2003 at 21:44
I purchased the Defense Pak system in
Brisbane QLD the remote is black & has 3 buttons, top button locks the car and enables immoboliser, the 2nd button when pushed once unlocks drivers door and pushed 2nd time unlocks all doors, 3rd button has boot release.
if you can sugest any solutions it ould be great
jamie
303628
Follow Up By: Xtra - Wednesday, Dec 24, 2003 at 23:13
Give this a try.
The system has to be disarmed before programming.
Disarm the system with spare remote or use the override.
With the drivers door open.
Turn the ignition key from ACC to ON 7 times on the 7th turn leave the key in the on position, the
hazard lights will flash to confirm its ready to program.
Press the top button on the remote
the hazards will flash 4 times to confirm the remote has been accepted.
If that doesnt work try turning the key from OFF to ACC instead of ACC to ON.
Still doesnt work try Defense Pak QLD on 1800 773 309
Dan
303634
