crusier,67 diffs change to 75?? is it the same?
Submitted: Wednesday, Dec 24, 2003 at 00:25
ThreadID: 9308 Views:1990 Replies:3 FollowUps:3
hey guys , well the "yeah the motors in A1 conditoin" is not in A1 condition it f#$%ing blow on me the other day,
got one on the way , so alls ok there, My Question is are all the chasis all the same on the land cruiser's? my chasis is 1967 ,from about 1969 the idler arms on the chasis changed, but what about the DIFF'S? from a 1975 maybe 1980, Springs as well still fit???
ron
Reply By: Member - DOZER- Wednesday, Dec 24, 2003 at 09:17
Hi Ron
There was some major diff-erences around that era. Havalook at yours and let us know....
Your diffs....does the rear one have a unboltable cover on its ass, or is it unbolt and pull out the front type?
Your transfer....is it 2 halves bolted together (top and bottom) or (front and back)
Everything changed between 75 and 80, transfers, diffs, etc.
But everything was also interchangeable early to late :-)
Andrewwheredayathinkwer mike?
AnswerID: 41020
Follow Up By: ron1 - Wednesday, Dec 24, 2003 at 12:19
g'day and thanks andy ,
the diffs on the old girl are bolt it the front type and transfer is bolt back the front ,
im picking up a wagon this weekend its a 1975 to 1984 model, (havent seen it yet ,just bought it for the motor, but have been thinking the the diffs might change over ,mine being a work difs and the wagon being a hwy diff, not to mention the gear box and transfer might be in better nick then mine,, mainly just hoping the diffs will bolt straight in, i want to swap both rear diff and leaf springs over, and front diff (maybe springs as well) any way guess it gives me lots to thinik about,
i'd like to maybe think about cuting the rear off the wagon making it into a duel cab, and put a tray on her , just a thought ,
cheers andy
ron
FollowupID: 303594
Reply By: Member - DOZER- Wednesday, Dec 24, 2003 at 12:39
Ok just so we r clear, you have the later diffs and transfer in yours. (dont know what it is exactly)
The wagon u have bought is a troupy, diffs should be thesame ratio (4.11) as the original blown motor cruiser.
Rear springs on the troupy will be longer than what u have if it is not another troupy.
AnswerID: 41034
Follow Up By: ron1 - Wednesday, Dec 24, 2003 at 13:06
yeah the gear box and motor was an upgrade on the tray back (one with blown motor)
the other is a wagon(4door) not the troupy model, will that make any differances ? in the spring length? and my diffs are 1967 model and i was told the diffs in the wagons used a high way diff ? this not true you think?? the tray back is a long wheel base as well if this helps
cheers again andy
ron
FollowupID: 303597
Reply By: Member - DOZER- Wednesday, Dec 24, 2003 at 13:40
You might be lucky with the rear springs, but think you will end up putting some of the leaves in yours. The diffs of yours are later models which is good but the ratio is 4.11. If the wagon u have bought is a 55 series 3 speed gearbox, 1975 model, it may have 3.7 diffs.
Andrew wheredayathinkwer mike?
AnswerID: 41039
Follow Up By: ron1 - Wednesday, Dec 24, 2003 at 13:50
the wagons a 4sp with a 2F motor
i have msn if you like to chat about it
add me ronsdream@hotmail.com
FollowupID: 303603
