Prado Grande Air Conditioning
Submitted: Saturday, Dec 27, 2003 at 22:24
ThreadID: 9347 Views:8050 Replies:6 FollowUps:2
Wondering if it is just my vehicle or do others with the split air conditioning system fitted to the new model Grande find it ineffective? On hot days it just doesn't get cold in suburban stop start motoring.
My wife's Pajero is like an ice box in comparison.
Nugsdad
Reply By: Martin - Sunday, Dec 28, 2003 at 00:13
My TD GXL aircon is absolutely excellent. High 30s, stop start etc no problems. It's not the split system but yours should be better so back to Toyota. Remember the aircon is dealer fitted so they should be able to fix it with no hassles.
AnswerID: 41185
Follow Up By: Member - Nobby - Sunday, Dec 28, 2003 at 12:56
Martin.. my Jackaroo's Air gets so cold I'm told to turn it down. We are in Bris. with temp at 30deg at the moment. I would be talking to Toyota.Jack at sleep
FollowupID: 303738
Reply By: farmer - Monday, Dec 29, 2003 at 16:33
My TD GXL Prado's air con is also not very good on warm days. I had it checked out at the 10,000 km service . Gas in the viewer seemed very low --- a lot of bubbles also. They said everything was ok . I think they said the air temp was 7c. I think I will now get the windows tinted. The huge slope on the front window doesn't help. Even when the sun is straight above you you have a lot of sun on you. I do not know why they have to have such a slope on the front window on a 4wd. Look at the disco's , built like a brick but still gets good economy . I had a sunvisor on the hilux , worked really well. Toyota don't make sunvisors anymore . The year 2000 when I bought double cab Hilux was the last time they built them ??
AnswerID: 41250
Reply By: Bob Y. - Qld - Monday, Dec 29, 2003 at 21:34
Nugs,
Would check the sight glass on the drier, or it mat be a little alloy square on tube leading back to firewall. On mid-cycle the glass should be clear, with no bubbles. If it's milky or bubbly then feel you would need a top-up.
A lot would depend on colour of your car, darker colours will take longer to cool. We have four toyotas here, and even in 47 degree heat here last week, they would cool down within a few minutes.
Hooroo...
AnswerID: 41264
Reply By: Phil G - Tuesday, Dec 30, 2003 at 10:11
I think there were some issues with the new 120 series air cond. 90 series was OK.
And the RV's and GXLs had dealer fitted air cond. The dual system on the Grandes were factory fitted.
AnswerID: 41310
Reply By: ** - Wednesday, Jan 07, 2004 at 09:56
I have the same car and same problem. OK at high speed but at low speeds its will not blow cold for long. Could only manage 14 degrees on a recent 36 degree day.
Climate control does not seem to work either. Always having to move temp up and down manually.
Refrigerant levels are OK. Dealer looked at it on Christmas Eve and found nothing obvious but has ordered a new TX valve to see if that is the problem.
I'm told its not related to the aircon but does your external temperature display take a long time to register the true temperature. Mine takes about an hour to catch up with reality when driving off from cold.
Howard
gosforth@optusnet.com.au
AnswerID: 42025
Follow Up By: nugsdad - Thursday, Jan 08, 2004 at 22:26
Howard
I've had it back at the dealer (Sci Fleet Albion Brisbane) as some days when it was 30 outside it showed the temp as 18. Funny enough they told me nothing was wrong but it has worked since they had it.
The Air on this car has been a nightmare for me. The split system has at various times blown hot on one side and luke warm on the other, even when it has been set on cold. Then it started blowing warm air into the cooler box, and I still dont think that the air is anywhere near as cold as my wife's manual system in the Pajero.
Love the car but for $80000 on the road, you pay a lot more to have air that doesn't work, dead bovine on the seats, and sat nav which always takes you the long way. I guess the DAT is good but the hill start assist is the most useless thing that has ever been invented, Subaru perfected this 10 years ago.
Other comments are that there is a knocking at the rear of the car with the tanks full, which the dealer reckons is the fuel guage and no solution has been invented.
A small point but I am on my second drivers armrest as the padding crushed in the first one and now this one has done the same.
Additionally the battery died when the car was 3 months old.
Don't take me wrong the car is great but is yet another lesson that you should never buy very early in a model's life, wait to it is well sorted.
Steven
FollowupID: 304727
Reply By: ** - Thursday, Jan 08, 2004 at 23:14
Steven
Sounds like you have had very similar experiences to me. I thought I was just imagining the problems as I could never really pin down excatly what was occuring until the recent hot weather. I've driven Landcruisers for years and downsized to the Prado as it is featured better than the Sahara which I wasn't very impressed with. The 100 series air is brilliant by comparison though. I agree with your sentiments about early models. Mine is one of the first and I took delivery in April. My Satnav was wired incorrectly on delivery and absolutely hopeless. Now that its fixed it does help if you study the route it suggests before setting off on a goosechase of long detours along main roads. It still amuses me that parts of the Bruce Highway only have a 60 kmh rating on the DVD which makes the ETA function useless. I don't suppose thats Toyotas fault though.
I had the hill start assist checked at the dealer (Jonkers, Caboolture). They said it was normal. I say it does not work as claimed (i.e. it does not work at all) and made the same comment about Subaru, except it was probably nearer 20 years ago. Toyotas customer service helpdesk were not interested so I gave up. I don't think its neccessary anyway. DAT is just sales pitch.
As to the knocking, I don't have that problem (yet?) but the last time I was at Jonkers they were aware of it. I may be wrong but I thought they said it was fixable.
I do have a problem when the torque converter locks up. At exactly 80 kmh in top gear I get a vibration through the car which feels like mud terrain tyres have suddenly been fitted. It very noticable until it fades away at about 100 kmh.
Toyota have been working on a fix since April supposedly. Fat Chance. Another problem to live with I expect.
Having just spent a week on Moreton i'm actually pretty impresssed with the way the Prado went on soft sand on the Dunlop slippers. Unstoppable would be a good description. Most other folks seemed to be struggling in the deep ruts.
I'm annoyed about the stupid "sand scoop" vent built into the sump guard though. Need to get a proper guard made without scoop before next trip. Any ideas where?
Let me know how you go with your air. I'm still waiting for a TX valve to arrive from Toyota.
Howard
AnswerID: 42291
