80-Series chassie-body bushes or cushions
Submitted: Tuesday, Dec 30, 2003 at 07:24
Revs
Good morning All
Ive replaced the 12 bushes_cushions between the body and chassie on my 92, 80 series.I have been to Toyota,
Suspension specalists and numerous other off road companys yet no one can tell me how much tenchion to put on the bolts after replacement.I can get information on pollyurathine lift kits but not the original rubber bushes as no one seems to have had the experience to replace them as yet There is no information in the work
shop manual.. Any help or information would be appreciated
Reply By: Bob Y. - Qld - Tuesday, Dec 30, 2003 at 09:02
Revs,
How come you had to change these bushes? Can't help you with the tension.
Hooroo...
41306
Follow Up By: Revs - Tuesday, Dec 30, 2003 at 10:03
The crush tubes were coroded which can not be seen unless taken out & the cushions were cracked
Regards Revs
303830
Reply By: Member - DOZER- Tuesday, Dec 30, 2003 at 09:07
Gday
When these bolts are done up, they end up home steel to steel, with the rubber supporting the body having a steel inner. The bolts are roughly 12mm, so i would say going by their size, 40-50nm. It is impossible to squash thew rubbers too much, overtightening will either break the bolt or strip the thread.
Andrewwheredayathinkwer mike?
41307
Follow Up By: Revs - Tuesday, Dec 30, 2003 at 10:05
Thanks Dozer
for your help
Revs
303832
