AnswerID: 41646 Submitted: Saturday, Jan 03, 2004 at 14:04
Mick
replied:
Ive done it myself in the old gq & Mq with the sanden sd508 comp, i filled it partially with oil and fitted a water separator on the outlet line so the oil and water could be drained out every once in a while, depending on how often i used it.
The other thing to do is strip the compressor and block the small oil lube pipe which pumps it back through the system. I havent tried it yet as my new trucks the GU, but i have stripped an old one & found how to do it, quite simple.
Endless air supposedly remove the old bearings and fit fully sealed bearings in them but VERY xxy!
Reply 5 of 5
