AnswerID: 41838 Submitted: Monday, Jan 05, 2004 at 15:38
David N.
replied:
Further to the above...
The biggest problem with 'van
tyres most people have is underinflation.
Light truck radials have a rating in kilogrammes which ASSUMES MAX INFLATION PRESSURE>
ie: if you run them at say 40psi (from a max of say 65 psi) then you have to reduce your rated load accordingly. Many manufactirers recommend a tyre pressure which is actually too low!
Also, just for info, I have an 18 month old 'van on which I was getting uneven (and rapid) tyre wear. Trouble is I discovered the problem after it was out of warranty. Axle was very crooked- manufactured that way I suspect, by a well known (german) manufacturer! (It was hollow with stub axles welded in each end.)
I tried to get some joy with them and the van manufacturer but got nowhere- had a new (stronger) solid axle made up locally for $115 which was easier than fighting a large corporation!!!!
Meanwhile I'm keeping my spare "as new" by keeping it protected from the sun etc!
Hope this helps- Cheers
Reply 3 of 3
