Battery charger problems
Submitted: Sunday, Apr 29, 2012 at 18:39
Nutta
Related Article
Battery Power
Battery Power
In this article we explain why you might need an additional power source independent of the ...
I hope someone can give me some input here.
I've got a projecta battery charger, Projecta MC121150 - Batteries Plus Technologies , in my van.
We left the 12volt fridge on last time we used it and screwed the batteries, now replaced with 2 new agm but the charger wont charge them, the red light comes on saying power but it wont go to charge or float, although if i pull the batteries and charger out and charge them on the ground it charges fine.
I hooked all the wiring back up the same way it came off so I know thats okay, I have no idea what else could be causing, so before I ring an auto leccy I was hoping someone here may have an idea.
Cheers in advance
Wayne
ThreadID: 95241 Replies: 7
Views: 1143 FollowUps: 0
AnswerID: 484569   Submitted: Sunday, Apr 29, 2012 at 20:43
david m5 replied:
I have a Projecta 10 amp charger and don't think it is a quality product . Wouldn't buy another one. sorry cant tell you why its not charging.
Reply 1 of 7
AnswerID: 484581   Submitted: Sunday, Apr 29, 2012 at 23:32
The Bantam replied:
Most of these funky multistage chargers work best when there is a direct relationship with one battery.
I have heard reports that some can be confused by other loads in the system and even other wiring.
There have also been cases wher multistage chargers have done a spac and got confused and overcharged batteries.
While I like multistage chargers and there are some realy good ones arround I can see a very good case for simple old fashon 13.8 volt analogue power supplies to float cahrge batteries long term.
It worked reliably for decades in many emergency power supplies.
Reply 2 of 7
AnswerID: 484588   Submitted: Monday, Apr 30, 2012 at 01:49
Nomadic Navara replied:
Put the batteries and charger back. Disconnect all loads and check the charging. That should work like when you have them on the ground. When you have things charging normally, reconnect your loads one at a time and see what happens each time.
Reply 3 of 7
AnswerID: 484593   Submitted: Monday, Apr 30, 2012 at 06:56
Nutta replied:
Thanks for some constructive answers, I will try that NN, good idea, cheers, Wayne.
Reply 4 of 7
AnswerID: 484597   Submitted: Monday, Apr 30, 2012 at 07:57
Member - John and Val replied:
Wayne,
If it all works when set up outside the van then the charger is ok. Either your reinstalling in the van didn't go quite right, or there is something in the van that's causing trouble. I'd check your installation first - are the positive battery terminals connected together? ditto the negative terminals. Is the charger positive connected to the battery positives? ditto negatives.
If your installation checks out, as Peter suggests, I'd disconnect all loads and if that fixes it, add them back one by one until the charger won't start. This should isolate the trouble maker. My gut feel is that the fridge may be providing a heavy load that in company with the batteries is upsetting the charger.
J and V
- Albert Einstein
Reply 5 of 7
AnswerID: 484629   Submitted: Monday, Apr 30, 2012 at 13:56
lesterb replied:
Are you sure the original batteries were screwed? Did you try connecting them to the charger without any load? I suspect that having the fridge connected across flat batteries is the problem. My fridge has a label inside that says it draws 12.5A on 12v DC. When connected and on that would only allow another 2.5A from a 15A charger for the batteries. Maybe it is the charger output overload protection kicking in.
Reply 6 of 7
AnswerID: 484663   Submitted: Monday, Apr 30, 2012 at 20:12
Nutta replied:
Thanks for the help guys, i'm not so sure the batteries were stuffed, i may have jumped the gun, never the less they are long gone and now i have the agms in.
I did have them connected separately outside of the van separately but not together and each one charged, so tomorrow i am going to take them out and connect them together on the charger, at least i can start working out if its the both together that is upsetting things, if it charges then i will try putting one wire on at a time as nomadic navara suggested.
I will read up on the overload thing and see if that may be it.
Cheers again.
Wayne
Reply 7 of 7
