AnswerID: 486293 Submitted: Sunday, May 20, 2012 at 13:16
olcoolone
replied:
A thermoelectric fridge uses a lot more power then a compressor fridge will and in general is usually made of cheaper material and components, one bonus is there are no moving parts ..... the thermoelectric fridge range is designed for the occasional or budget user who doesn't require a real fridge or where cooling is not critical.
Thermoelectric fridges will only cool to about 20 Deg. C below ambient temp ..... if you have it in a car and the cars interior is 30 Deg. C you will not get much more then about 10 Deg. C cooling in the fridge, if it's 40 Deg. C ambient expect 15 to 20 Deg. C inside .... not quite cold enough for a beer!
On advantage of a thermoelectric fridge is they came also warm and work much better as a warmer then a cooler.
Most thermoelectric's are usually called cooler/warmers NOT fridge/freezer
Thermoelectric fridges are a bit of a toy, save your money and reduce your looses and by a compressor fridge that you can use for many years to come knowing it will work in 40+ ambient temps and keep your beer where it should be at 4 Deg. C.
Reply 4 of 4
FollowupID: 761555 Submitted:
Sunday, May 20, 2012 at 17:42
Member - Boo Boo (NSW) posted:
It depends on where and what you want to do with it.
When we had the troopy we had one between the seats for 6 yrs and it was only used to keep drinks cool when travelling in most
weather conditions and could not fault it.
For food etc we always used the fridges in the back of the troopy.
| Regards BooBoo
How are you? Well you woke up this morning so ya gotta be feeling good! |
FollowUp 1 of 2
FollowupID: 761556 Submitted:
Sunday, May 20, 2012 at 17:43
| Regards BooBoo
FollowUp 2 of 2
