FollowupID: 762042 Submitted:
Saturday, May 26, 2012 at 13:33
olcoolone posted:
More then likely an earth problem. there is a common black wire to your headlights and indicators...... the left side has a separate earth point to the right.
What you can do is get a bit of insulated electrical wire and make contact with the black wire on the headlight globe holder and the negative on the battery.
If your problem disappears then you have to start looking for the earthing problem.
Just to note your left hand indicator should have the following wires:-
Green/yellow +
Black -
And your headlight should have the following wires:-
Red/green Low beam +
Red/blue High beam +
Black Earth
The earth point for the left hand side is the 10mm bolt behind the left hand headlight on the inside guard, the right hand side is the same but on the right hand side.
Hopefully that helped, any other questions just yell....
