AnswerID: 487011 Submitted: Monday, May 28, 2012 at 17:12
Member - Bruce C (NSW)
replied:
Hi G.T.
Cannot advise on the brand you are refering to or the price.
However, a mate had a set of those strap on mirrors which attache to your existing mirrors and he said that they were never the best answer to the problem.
Eventually one vibrated loose and fell onto the road way down on the
central coast NSW and that was the end of that.
He now has a set of the Aussie Truck mirror types (same style but different name)
and is more than happy with them. He modified the window rubber to accommodate them where they slip in beside the window glass..
I was lucky that my nephew had advised me to get a set of the Aussie Truck Mirrors, several years ago, and I did so and was always happy with them on my 80 series.
I damaged the window glass on my 2003 100 series Cruiser with them so I now have a set of Clearview mirrors (very expensive), as a replacement drivers door window would not be cheap.
Cheers, Bruce
| At home and at ease on a track that I know not and
restless and lost on a track that I know. HL. |
Reply 1 of 2
FollowupID: 762266 Submitted:
Monday, May 28, 2012 at 19:32
toyotarules posted:
Lol it did the same with my 2003 100 series the tint on both sides so now I run the clear view mirrors to and love em
FollowUp 1 of 2
FollowupID: 762278 Submitted:
Monday, May 28, 2012 at 20:49
Member - Bruce C (NSW) posted:
The problem on the 100 series seems to be that there is less room between the glass and the outside metal on the door or the cover strip incorporating the wiper rubber is wider and the wiper rubber thinner. Either way there is less room for the mirror bracket.
I know the rubber does not like to be scrunched up tight under the mirror bracket as it requires a fair bit of tension to keep the mirror bracket away from the window glass and the rubber takes several days to regain its shape once the mirrors have been removed.
I heard of one person who busted their drivers window and then decided on fitting the Clearview Mirrors.
I fugured I would not wait till I busted the window before I acted. I think I took the cheaper option by fitting them now.
This problem did not occur on the 80 series and it is probably OK many other vehicles as well. It just seems the 100 series is the issue.
My mate actually cut the rubber away with a razor blade on his 98 model 100 series to fit the truck mirror type. He is very happy with his mirrors.
Cutting the wiper rubbers was not an option for me.
Cheers, Bruce
FollowUp 2 of 2
