Overheating GU 4.2TD
Submitted: Friday, Jan 09, 2004 at 00:24
ThreadID: 9600 Views:7293 Replies:7 FollowUps:4
While towing a van my 2002 GU4.2TD aircond. cuts out when in the hotter areas of Australia. Three sensors, 2 located at the base of the radiator and 1 on the thermostat housing control this temp sensing and when all three are unplugged the aircond remains on but the engine temp soars due to the extra heat generated from the condenser. The family was not happy on the last trip to NT(40deg heat with no aircond and yes I know they are spoilt) Has anyone had experience overcoming this problem. I have read that the GUIII has a larger radiator than previous models (taken from the 4.8) and would it be a direct replacement for the earlier version.
Cheers!!
Reply By: GUPatrol - Friday, Jan 09, 2004 at 10:28
Goldfinder,
I recently replied to someone on the Patrol forum with regards to this, see below:
The 4.2 Diesel GU Patrol has two switches on the bottom radiator tank.
The one at one end switches on the electric fan (in front of the radiator) when the temperature on the bottom radiator tank is getting too hot few degrees higher than normal.
The one on the other side switches the A/C compressor off a few degrees higher again to releave some of the heat load because while the A/C is going the radiator is getting hot air from the condenser.
In other words, if the radiator is not coping the fan starts first, if that is not enough then the a/c compressor is cut out to give priority to the engine cooling instead of the passenger's comfort.
In the 3.0L and the 4.8 that is all controlled by the ECU, hence no switches at the bottom of the radiator. In fact the fan has two speeds and through the ECU the 3.0L model switches the fan at low RPM and then higher when needed.
IF you look carefully you will find that the shroud is split with one side having straight through square ducts, the viscous fan cannot cool down that area of the radiator so on a hill at high revs and low road speed the radiator size is reduced to 80% because the fan drawing most of the air cannot draw through those ducts (air filter side), that is when the electric fan cuts in and cools that side and gets 100% air flow for cooling .
In my opinion the radiator is too wide and too short (that is probably why the new 4.2TDI has a different radiator, narrow and long).
I never had any problems with mine only once on a very hot day in first low in the high country the a/c cut out, however recently the a/c cut out flogging it up a hill so I decided to clean the radiator fins etc (as suggested by Bazzle several times) and I found it all blocked with dust, leaves and feathers from an emu I hit near Tibooburra.
The process involved removing the radiator, blowing it through with air "while still dry" and then washing it up and blowing it again.
To check it, it is quite simple, when you remove the radiator it may look OK (not dirty) but you must be able to "see through" the fins, the areas you can't see through are blocked to air flow.
The reason why it should be done "dry" blowing with air is because insects, grass and seeds swell when you wet them and then you can't remove them.
The GU radiator is a single row type all alloy and the fins have slots in them which catches those little black night insects, the dust then gets cought behind the insects and the blocking process starts.
It took me all afternoon of blowing air and I still could not get 100% of the insects out but I could see through (by the way I have always had a mesh since new) but these insects fit through the mesh and the A/C condenser.
I took the chance to change all radiator hoses at the same time and all belts.
While I was at it I blew the a/c condenser through as well.
I have tested it since and it is fine.
Also make sure the viscous fan cuts in, I can hear mine roar as soon as there is a hill or the outside temperature is high.
I believe the overheating problems everyone reports on 4.2 engines are a combination of three things:
1) Cast iron head indirect injection (combustion in those engines happen further in the head than in a direct injection and it is designed to heat the air on compression) and cast iron does not get rid of heat quickly (Just the reason why camp ovens are so good for cooking).
2)Engine design, water jackets too small and slow flowing designed for low engine speeds.
3) Radiator too short/small with shrouds not designed for good air flow at low road speeds.
Taking into account the first two points while driving should keep you safe, lower RPM and lift throttle when the going gets tough, the 4.2 will still pull at 1500 rpm...
I first knew there was a heating issue with these engines when while driving mine new up a hill on freezing temperatures outside -5 the viscous coupling fan engaged and roared all the way up hill... If it did that while on -5 degree temps what hope do they have of cooling efficiently if the outside temperature is 45 degrees and you are towing a heavy trailer??
Will
AnswerID: 42330
Follow Up By: Roachie - Tuesday, Jan 13, 2004 at 15:11
I also own a 4.2T/D (2000 model) which has a temperature issue. I can live with the fact that the temp gauge is going off towards the right, but I'm not prepared to live without the aircon on a real hot day. I've done a few things already....On New Years day I took to the bonnet with a drill and jigsaw and cut a rectangular hole opposite where the 3 litre ones have there scoop for the intercooler. I bought a genuine Nissan scoop for $110-. I originally mounted it backwards, hoping it would allow hot air to flow out towards the windscreen, which it did; but on a 40 degree day the temp still went up too. So, now I've turned it around and have it facing the front. It is situated right above the turbo. On the weekend I was coming back to Kadina from Adelaide up the Hummocks (a moderately sized hilly area about 100klm north of Adelaide). The outside temp was only about 30deg, but I kept the aircon on and tried to attack the hill as hard as I could (there are a couple of 65km/h bends going up) and the old girl still went over half way again. I've moved my Lightforce 240 Blitzs to the top bar of my ARB steel bullbar. I have a 10" Davies Craig fan situated in front of the aircon condenser (right side). I've removed the plastic "mud plate" from the bottom of the chassis, but have left the steel ARB plate under the winch, in place. I have a full 3" exhaust with a simple Lukey "hotdog" muffler and no catalytic converter (this includes a custom made dump pipe from Binskins at Wauchope, NSW). I'm now in the process of getting my local radiator mate to see if he can get a custom made 3 core radiator to fit between my tanks. He reckons he'll also put a cooler thermostat in and I reckon I'll get him to check/top-up the viscous fluid in the fan too. I've also thought about the Davies Craig dual thermo's, but have heard too many bad stories, especially about them not liking water. I will post more info about the 3 core radiator if/when I get it sorted.
Roachie
FollowupID: 305132
Reply By: chrisfrd - Friday, Jan 09, 2004 at 14:38
The best solution that I've seen for GU 4.2's and some 3.0's is to remove the viscous fan all together, instead fitting two large thermofans in it's place.
This allows N+1 redundancy and high flow rates around the airconditioning condensor (supplied with it's own fan) and exchanger core.
My 3.0TDi has two Davis-Craig DSL16's, one configured for pulling, the other for pushing the air. This allows you to dispense with that STUPID plastic shroud and effectively cool the whole engine.
My question to you is; Have you changed anything on the front of the truck? For example, Large bullbar, driving lights or fly-screens? Anything that would reduce airflow? If you are using the standard Aluminium Nissan bullbar, have you taken off the plasic shroud at it's base?
If you have, then try testing the effective airflow under the bonnet, in front of the grille by using an airflow meter of some description. I bought a Tandy unit for this purpose. It has two output pins for the tacho, that you plug into a multimeter, set to tacho.
If all else fails, you can "up rate" your exchanger, but this will cost heaps of money and potentially ruin your warranty claims status. SImilar to what I've done with fitting thermo fans!
Another thing about Thermo's.. They don't like swimming that much. I tend to put a blind over the front of the car if fording more than 500mm. I've also designed a small PIC-based computer that runs the thermo fans on for up to 10 minutes after engine switchoff, to cool water/engine on hot days. As you would know, engine temps actually RISE after you shutdown, as the cooling system is not powered.
Regards,
Chris Ford.
AnswerID: 42356
Follow Up By: AndrewX - Friday, Jan 09, 2004 at 20:21
Chris You'll get much better cooling down on a hot day if you leave the engine running for those 10 minutes with the fans going. The aim is to equalise the temperatures in the engine. There are some very hot areas on a hot day. As you are no doubt aware when the engine shuts down so too does the water pump and therefore there is no circulation of coolant. Thus by running the fans for 10 minutes you'll cool the radiator but do very little to cool the coolant deep within the engine. Been there and done that with the old Davies Craig fans. I found them to be of little value considering the hassle as you mentioned with deep water. The cooling problem which I was trying to solve by fitting them I found later to be caused by a faulty clutch on the OE fan on a Pajero. Electric fans are OK as OE on small cars but I think you can't beat a big belt driven fan for 4wd especially when the going gets tough.
FollowupID: 304841
Follow Up By: chrisfrd - Monday, Jan 12, 2004 at 10:21
Actually, you do!
You get thermalling within the block, as colder water displaces the hotter due to different pressures within the system.
For about 30 minutes, the system is still highly pressurised and will still cycle. On my old Nissan Rally car I had 10 years ago (a Datsun 200B with an FJ turbo motor) I had auxillary water pumps on that... Found them far too unreliable and ditched them with out probs.
As for unreliability of the electric fans? Hrm.. My Patrol gets abused almost weekly in some fairly harsh country and I rarely have problem with the truck, let alone the cooling system. Now that I've moved to the Festival State, I'll be bashing around the desserts without problems.
The clutch driven units are OK, but I like to be able to maximise cooling effectiveness by electric ones and if I get a problem with one, I'm running N+1 redundancy anyhow, so I can have 1 unit die completely and still go at maximum power everywhere.
FollowupID: 305016
Reply By: goldfinder - Friday, Jan 09, 2004 at 15:14
Thanks for the replies. Most of my problems occur at speed usually when towing at 90kmh plus so airflow at these speeds should be pretty good. To get the aircond to come back on I have to slow down to a very slow pace for a good 5-10 mins to allow the motor to cool. I do have a steel bullbar as fitted by nissan. I am willing to spend money to rectify this problem on an otherwise great car. Possibly an aftermarket manufactured larger rad. I will give the thermo's some thought as well.
AnswerID: 42364
Reply By: Eric Experience. - Friday, Jan 09, 2004 at 23:14
goldfinger.
Just a bit of engineering data to help you understand the problem. A motor is about 15% efficient, alowing for the heat out of the exhaust we can assume about 80% of the remianing heat goes out through the radiator, so if you are driving flat out you are producing 100kw from the motor that means 500kw is going into the radiator. I dont know if you have any way of comprehending that amount of heat but that is more than you use to heat a small shoping centre. So to solve the problem you must let the hot air get away from the engine compartment, the plastic sheet that is used to stop the mud from the front wheels getting onto the motor is a major restriction. another aproach would be to move the fan forward and then cut the cowling down to allow more air flow. This increases the risk of damage to the radiator in a minor collision. The hot air flowing agianst the fire wall and coming into the plenum chamber is what is over taxing you air con. Eric.
AnswerID: 42416
Reply By: Mick - Saturday, Jan 10, 2004 at 11:57
I fitted a DTS exhaust with a new turbo elbow. It has much less restriction and lets the heat out faster, and gives you about 15% more power.
Another idea is to put a slightly 1-2 degree lower thermostat in the engine, so it opens earlier, and lets the coolant cool down earlier.
Other than that, take as much un-needed junk out of the caravan and lighten your towing load.
AnswerID: 42469
Reply By: goldfinder - Sunday, Jan 11, 2004 at 10:08
Thanks all for the helpfull advice and I will take all answers into account to try and solve the problem but the bottom line is that a $60K vehicle with a rated towing capacity of 1300kg (I think?) and my van loaded would not be that heavy (jayco Hawk offroad Camper) should not have an underated cooling system. One for Nissan to solve!!
Cheers!!
AnswerID: 42550
Follow Up By: Roachie - Tuesday, Jan 13, 2004 at 15:25
Hi Goldfinder,
The rated towing capacity of the big Datto's is 3500kg (3 and a half Tonne) braked or 750kg unbraked. I totally agree with you that a $60K truck designed for the harsh Australian conditions, should be able to cope with 40+ degree days without the aircon giving up the ghost. My last Nissan was a 93 GQ diesel which I put a Safari turbo on and I don't recall it's air con ever switching off on a hot day. But I do remember that you could hear the roar of the viscous fan cut in going up the Clyde Mountain when I was travelling from Batemans Bay to Canberra. I did that trip ever fortnight (twice) to pick up and return my young son. Depending on the ambient temperature, I could just about predict when the roar would start. Now, with the newer GU (which I've owned since new), I have NEVER heard the fan cut in despite the outside temp being mid 40's etc. Maybe it's a quiter fan. Does anybody else actually "hear" their GU's fan cut-in? Maybe mine's stuffed and that's my whole problem?
Roachie
FollowupID: 305136
Reply By: goldfinder - Wednesday, Jan 14, 2004 at 10:35
Roachie I have never heard my fan come on in the Patrol or any other vehicle I have owned with a viscous coupling.
AnswerID: 42903
