magellan 320 gps to laptop
Submitted: Sunday, Jan 11, 2004 at 23:59
ThreadID: 9675 Views:2296 Replies:3 FollowUps:0
I have a 320 that I want to hook up to my laptop. I have the cable that came with the unit and I purchased a serial to usb cable so that I could hook it up to the laptop.
My problem is that my laptop and home PC will not pick up the device. Is there something I am missing? Do I need some special software or something?
We have oziexplorer and natmap raster.
Any suggestions would be appreciated
Jeff
Reply By: Mad Dog Morgan (Vic) - Monday, Jan 12, 2004 at 10:00
If you have configured both oziexplorer and the GPS to the same baud rate then it is probably the serial/usb cable, some brands don't work too well with some laptops.I may be mad but I'm not crazy
BEAM ME UP SCOTTY
â
Hooroo
Ray
AnswerID: 42647
Reply By: Member - Jack - Monday, Jan 12, 2004 at 20:41
Hi Jefrey:
I have a 310 (very basic unit) hooked into a Toshiba laptop.
Assuming that you have power everywhere, and you are outside, go to the Oziexplorer Menu to "Moving Map/Start NMEA Communication etc etc ...
As long as everything else is setup correctly you should get something happening.
JackNo trees were harmed in the making or sending of this message.
However a great number of electrons were terribly inconvenienced.
AnswerID: 42720
Reply By: Richard - Tuesday, Jan 13, 2004 at 20:39
Confirm I believe both devices need the same baud rate. This is a problem I resolved with my Magallen 315 many years ago. I would have though newer Devices and software would have been smarter.
AnswerID: 42856
