Battery Systems
Submitted: Monday, Jan 12, 2004 at 19:30
Yarn
I have a Jackaroo with an In-Line Duel Battery System, apparently necessary to provide cranking power in colder temps.
I understand this is not the best system for running the usual accessories such as Fridges etc. as both batteries are used.
My question is, what is required to modify the Standard system to a "true" Duel battery system or would I be better of installing another power supply.
Cheers Yarn
Reply By: Herve - Monday, Jan 12, 2004 at 20:27
Yarn ..... I have the 99 TD Jack with ONE main battery and an aux - has always started ok, but the Jack injection/oil story is a long one. Yours has the two batteries in tandem, because Isuzu stuffed up with the oil driven injection for cold climates and of course took the easy way out (what manufacturer doesn't ? - now you don't have room for an aux battery ! - but do they care ?).....two batteries in tandem means you can try and start it for much longer, in very cold climates. Its not a problem in mild climates. Significant accessories should not run from the main battery, because the Jack needs every amp when you are
camping out and wake up to find ice on the tent ! Suggest if you are not likely to work in extremely cold climates you install a battery isolator system (Rotronics etc) in the line that connects your two pos terminals. When you shut down, the current second battery will be disconnected. With accessories wired to the second battery, you main won't get flat. When you start up, you will only have the main battery on line - the isolator will connect the second battery for charging, when the first battery is happy. Check out the isolators at a good 4WD
shop - Rotronics are on the web too.
Thats how I see it."This is a situation, up with which, we should no longer put ! (W. Churchill, on plans to reduce 4WD access in some parks).
42716
Reply By: D-Jack - Tuesday, Jan 13, 2004 at 15:39
Howdy Mate - I am just a visitor to this site but have just decided to join up - it is awsome and full of really helpful info. re the Jackaroo - I have one, a 1999 turbo diesel, and like yours it has a twin battery setup. I recently went though all the pains of what I was going to do for auxillary power, and after talking to heaps of 4wd shops and auto electricians, here it is.
Anodised rust free heavy duty battery cradle ($120) replaces the one on the passenger side, accommodates the two starting batteries.
The starting battery on the drivers side gets transferred to the other side and sits right next to its brother. The re-wiring is pretty simple for an auto sparkie.
The battery just moved from the drivers side gets replaced with whatever you want - for auxillary purposes - I used to use a cheap 4wd battery ($85, N70ZZL or something like that) but it only lasted about 18 months (in my previous car). I recently bought an RAA one which they claim has a mixture of heavy duty/deep cell characteristics for $170 which should last longer - time will tell. The reason we did all this was because there is not enough room for a larger battery on the passenger side at all, and because the drivers side cradle is the one that they used to fit a bigger battery to before going twin, there is plenty of room for whatever size you want. I had the option of just having a smaller battery (say 520cca) as auxillary, but wanted more to keep the fridge running longer.
To isolate they used a redarc which if you want to know more about search for it on this
forum and you will see how much of a rap they get. My sparkie wanted $210 for it, but apparently you can order them for about $110 (again the search will give you details).
All up it cost me about $700. Not cheap, but for me worth it. Still has the original specified cranking power plus the benefit of a larger Aux battery. Go to a 4wd place and they would probably want about that much if you were going to use your existing setup.
This may not suit your budget or needs but I just present it as an option to consider. GOOD LUCK.
p.s. If you haven't already caught on - I'm not a very techincal person, which is why a got a sparkie to do the lot.
p.s.s. Have you done much 4wding in your Jack and how has the clearance been with that big fat metal thing on the driver side underneath that hangs down - I think it is the tranfer case or something. Also if anyone else is reading this does lifting the car raise this big fat metal thing up or not?
42818
Follow Up By: Yarn - Wednesday, Jan 14, 2004 at 20:08
Thanks for the heads up on the Battery process, it sounds like a good solution.
As to the metal plate, it is the Bash plate protecting the transfer box.
In most cases it does not cause a concern as long as you are aware that it is there and drive accordingly. It is a real pain when you are forced into deep wheel ruts in the track and yes, I have been caught (much to the amusement of my son) where I have not had enough momentum. I told him it was a training session with the recovery gear.
Yarn
305285
